just bought and fitted a set of split fire coils and planning to regap spark plugs. im want to gap them at 1.1 but am thinking why stop there? why not 1.5 or more?
I doubt they could run a spark that hectic ,I just recieved mine yesterday yet to install let us now what gap you can run b4 it breaks up (can't be bothered gapping the plugs so just gonna buy 1.1mm )
although the splitfire coils may be an improvement over standard coils it will never have the power of a CDI system that can run big gaps under high cylinder pressures.
let us know how you go though, doubt it will do 1.5mm gap myself.
That sounds like an interesting idea. I'm running a set of stock coils in my car atm, and they are in very good condition. I run a 1.1mm gap no problems at 10psi.
Perhaps if the splitfires are better, you might be able to run a bigger gap. Only one way to find out. Try it.
And the point of this being what?
:confused: :confused: :confused: :chairshot :chairshot
More efficient combustion ,more fuel burnt equals more power
I found this article on a site ....We haven't seen any benefits of gaps beyond 0.045-inch, so that should be the outer limit of sparkplug gap. Don't re-gap sparkplugs too many times because the ground strap metal will fatigue and may break. If your engine makes more than 75 horsepower per cylinder, gap the plugs only once. If your engine makes more than 100 horsepower per cylinder and/or sees extended periods of high RPM and/or high boost, we'd have to say don't gap the sparkplugs at all! (Here, it pays to use high-quality plugs that have a consistent gap as-manufactured.)
I done this little exercise as i have splitfire coils. Gapped at 1.1mm and running 20psi, it missed. Gapped them down to .95 and it still missed. Just above .8 i gapped them at and now i have no miss. Remember im running alot more boost though.
There might be something about this on the NGK website. And I recall someone (Zoom! or Autospeed) did this comparison a while ago.
You need to have a coil that can generate enough energy to jump the plug gap. Even if if can, it may be so borderline in strength that it actually causes a worse burn than the narrower gap could produce. This is often why you need to gap down at higher boost levels - the poor spark is more susceptible to the higher cylinder pressures that come with increased boost.
There's a lot of physics and chemistry involved - it's not just a simple matter of saying that a bigger gap will produce a better burn.
sorry to say this: but dave got :Owned:
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
