ok people i have r33 dual pillar mount by Greddy..its still new in box, has all new screws still in plastic...wanting $120ono as cost $180 new... pm me or 0422210591
or if you have a s13 silvia/180 dual mount i will swap happily..
btw i'm in perth and buyer pays for shiping
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
