why the f@ck will u get fined if ur car is unlocked?
doesnt matter whether ur driving or parked....thats totally BS!
No, its only when you leave the car unattended (and I'm assuming you won't be driving in that instance).
Its to stop people from leaving their cars unsecured and walking off, and then having a cry when someone opens the door and steals shit from it. In the past you could make an insurance claim on it (since its theft), but now since you've broken the law they don't have to pay out.
Which is fair enough. Why should insurance companies pay out for your stupidity? If your car was locked and someone broke in, fair enough. But if you're too much of a **** to even lock your own pride and joy when you wander off to pay for petrol or whatever, you deserve what you get.
I could have sworn this law was enacted a couple of years ago. I must have remembered wrong, but in that case they introduced a law a while ago making it illegal to leave your keys in the ignition (car running or not) while unattended. Same reason - people would walk off, and someone else would just hop in to the car and drive it off. Technically its theft so its insurance claimable (and it was costing them quite a bit), but not when you did something illegal to enable it to happen.
  • Replies 44
Ok
Rule 78 (2) Not move out of path of police/emergancy vehicle : Fine level 6 $300 and 3 points!
Rule 66 (4) Proceed after stopping at twin red lights Fine level 6 $300 and 3 points.
What the hell do you do when there's sirens blazing behind you and your the first car at a red light?!?!?!
I heard stories of someone getting fined for proceeding cause you don't have the authority to proceed even if the cops/fire/ambos are behind you honking their horn at you.
Rule 265 (1)&(3) Passenger 16 years or older not wearing seatbelt. Fine level 5 $225 points 0
Rule 265 (1)&(4) Passenger 16 years or older in front seat when not permitted. Fine level 5 $225 points 0
Umm... thought this was 3 points?!?!?!
http://www.rta.nsw.gov.au/rulesregulations...its_general.pdf
page 5 line 4
No points for transit lanes.
Which is nice since I have drive in one every day for 5+ years now. Which for a $175 fine would make it 13c per day if I get caught one day ;) If there were points i probably would not use it.
Ok someone want to explain the diff between a T way, transit lane and a bus lane (3 points for a bus lane)
Isn't it nice that if you right off another veichale cause of neg driving you get the same level of offence than driving in a bus lane... mmm makes total sence to me (not)
T-Way usually have signs stating T-Way. its the Bus Only Lanes.
and Transit lanes I think are just the T2 or T3.
T2 = two passangers in the car
T3 - Three Passanagers in the car.
kinda makes it worthwhile car pooling.
page 5 line 4
Which is nice since I have drive in one every day for 5+ years now. Which for a $175 fine would make it 13c per day if I get caught one day :rofl: If there were points i probably would not use it.
Don't try to justify your crime....you......you....criminal!!!!
lay off dundan. he needs all the help he can get to be at work on time. I see Kel and duncan like to stroll into work at about 10am by my calculations. go that transit lane son!!
  • 2 months later...
I seriously don't understnad this shit about T2 T3 in Australia, Im from NZ and we don't have that there at all which makes it a lot less confusing, so the majority of time I just ignore it. Now, what is the point to all of lane thing, is it a safety thing or something?
I think I've missed the point with Rule 151(4): Ride motorcycle more than 1.5m from another. I guess than means I can't leave the house unless I have a riding buddy...
Bring on more fines for not keeping left.
Bring on more fines for rear fog lights and highbeaming.
Bring on more fines for hand-held mobiles.
And the best one, Rule CI96A(2), $50 for "Riding bicycle furiously!" Nice.
Guys what's the difference between a burnout and an aggravated burnout?
AMEN TO YOU BROTHER. im sure it is only if the car is running unattened ie fueling up; turbo timer must be shut off b4 fueling up.
this also means turbo timer must be off even if you want to hang a shit. how ever my freinds ive argued the point when there was a passenger with me that it was not unattended and got off !!!!but i think it was pot luck.
agravated burnout is when you have one arm out the window flipping someone the bird. or if you are doing it on somones front lawn.
Damn. Then they'd probably fine me for having part of my body outside of the vehicle too.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
