I Suggest We Kick Out Anyone Who Buys These..
  • Replies 78
lol dunno bout holden shite, but its these rims...
in 20"x11"wide in front and 20"x12" in the back going on this car
with this spinner (for shows n shite, probably not for general road use)...
secured by 5 lugnuts with locking heads to the hub
so that would make the wheels worth half of what your car does chris :rofl:
  funkymonkey said:
That's actually pretty hot.
That'll look good when it's up and working.
Nice work :(
Shan your lights look better because you are keeping the red lens covers, so in the day time you will not see the LEDs.
Just my opinion: If you used the bigger LEDs and only set the LEDs in a ring (just like the e-bay items) it will look better. As i said just my opinion, no offence intended.
al, yeah I didn't notice the ebay ones were fully clear, which yeah, does look pretty ghey.
so you reckon instead of going for the stars I should go for rings? hmm will try photoshopping it to see what it looks like. Basically all I've done so far is replicate a set of nismo ones for the R34 using instructions I found in a jap magazine.
When the ebay lights are lit up (as above) they look good. Notice that the big LEDs are being used ;)
It's only when they are not lit up, then you could see the LEDs, with the red disk in the middle and chrome surround, that the ebay lights look shit.
if you're referring to my daily driver, then no, its about on par actually ;) but its serves its purpose, along with the other 2 cars I own :) I like to spread my assets.
  funkymonkey said:
if you're referring to my daily driver, then no, its about on par actually :) but its serves its purpose, along with the other 2 cars I own ;) I like to spread my assets.
lol shan, make me up some of those lights with the LED's ;)
I felt the same way when first got them actually I straight out didnt like em butt their growing on me and they do look like retro rockets.Only downside is getting a red globe that doesnt shine pinky or brown which isnt easy to find.
And S%$t i didnt cover the no plate up even though not sure why its done.
Chk out the afterburner lights i put on a 300zx im just doing.72 of them nearly make your eyes bleed if your tailgating. :crazy: :crazy:
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
