There are a few other little differences, but the easiest to check for and most reliable is just looking at the front brakes... If they look big with 2 round bits it is a type m, if they are small, its not.
Personally, i have never seen a non-type m R32 in Australia, but this might have changed with the amount of 89 cars that are in the country now. With SEVS it wouldnt have been worth bringing them in.
Options such as sunroofs, upgraded interior and even the "type-m" front bar are not reliable ways of telling if its a type m. The type m front bar is an option on both the non type-m and the type-m models.
My type m has the upgraded interior (gtr-like cloth), driving lights, rear wiper, big brakes, but doesnt have the type-m front bar. (it does have a crome grill insert though)
the front brakes are crappy singles.. but $300-400 will see you a nice set of 4 pots to fix that issue up. Some say the diff is non-LSD on them, but not sure, as mine has an LSD. Otherwise the stabaliser bars might be a little smaller..
xRHETTx - well meet one right here :)
i have seen quite a few non type m 89 r32's coming in at the local dealer down the road.
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
