  • Replies 316
Posted Images
Basically the new gen core is rated to flow more, the older core is rated to flow less.
If it's possible to use the new gen core with the internal gate housing i'm not sure, if it works well is another thing, you may experience surge with a small exhaust a/r?
Bullant.
You mentioned the GCG may bring back the 500 hp turbo, but woulld have to address the size of the wastegate in order to make it commercially viable.
Did they offer to enlarge your wastegate?
I once spoke to them about highflowing my turbo and I asked if they could make it bigger, and they said no problems.
Just a thought.
Any further reflections on how the turbo performs?
Have you done the 2nd gear from walking pace test? When does she begin to boost?
BASS OUT (Still searching for a VG30DET Exhaust housing)
Sorry i dont know about a 500hp hi flow.
2nd gear boost starts at about 2200rpm and makes a lot of wheel spin at about 3700rpm.
3rd gear boost starts at about 2200rpm and makes full boost (19psi) at around 3800rpm.
It ramps up very strong and really fast in between these revs.
I did the same thing in my car as have a standard turbo for a comparison (mods are in sig). I did it by just idling along in the selected gear than just held it flat.
2nd gear boost starts at 1000rpm and full boost 11psi at 3000rpm.
3rd gear was exacly the same.
So to me it looks as though boost comes on 1000rpm later but spools just as quick or quicker than stock. You have got to be happy with that very impressive. I would like to see people do the same tests with 2535 standard gcg highflow ect for interests sake.
:D
Bullant.
The issue with the old GCG 500hp highflow wasn't boost creep (where boost cannot be kept down, creeps up as revs increase) the issue was with surge.
A larger exhaust a/r was needed to help shift the full spool a little higher in the rev range where the motor can consume the air better.
I'm unsure of the differences between the 500hp and 450hp highflows they offered, I assume it was the compressor size.
It looks as if the GCG Highflow on the rb25 would be very similiar to the XR6 Turbo on the Rb30. Spool wise. :D
I did it in mine today. Stock Rb20DET Turbo running stock boost. :D
Boost and surge under 2000rpm, as soon as 2000rpm hits it kicks and breaks in to a wheel spin at this time it looks like its wheelspinning around 2300rpm or so. :)
Just a pitty the power drops off rapidly after 5000rpm and peak power is made around 4400rpm. lol
Cubes yes , the GT30 housings will fit early and late cartridges as will any housing machined (profiled) to suit .
Garrett often sells cartridges without exhaust housings so the end user can select one of several to suit his/her application . If you look in the old Garrett catalogue PDF the "GT3071R" (700177-23 CHRA No) is sold as a cartridge without compressor or exhaust housings but there are three variations of both turbine and compressor housings available .
The integral gate HKS housings are the go and while expensive not as much as an aftermarket cast manifold and waste gate . GCG can get HKS housings (as I suppose HPIAB could) and if enough people were interested they could possibly market these with late "GT30R" turbochargers that will bolt up and take advantage of all the available technology .
Cheers A .
Got any pics?
No sorry, I only had the VG30 in my possession for about 15 minuites. GCG got it and opperated on it almost immediately...It was complete with dump, 02 sensor and in good condition actually.
Hey on another note, I went back to C&V for a touch up on the tune cause along with the massive power the car is making, some knock was occasionally observed on the Power FC. It appears that the R34 fuel pump is maxed out and A/F is leaning out at high speed (around 180kph). Next week a Bosch 044 and swirl pot is being fitted to keep the A/F line straight on the graph. Con recons the turbo is so efficient that with more fuel he can make a lot more power safely. After he played with the high end fuelling and took out a little timing it actually made 273.9kw@tw. 3kw more than before. So be prepared to think about fuelling cause the GCG Hiflow with the VG30 turbine housing sees the end of the GTR fuel pump upgrade. I'll post up the dyno sheet when i hook up the scanner.
Ian
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
