Time I emptied the old tea bags and cleaned the spoons I think. lol.
Haha never noticed until you pointed it out Cubes :D
Thanks for the pics and measurments, this will aide those looking immensly.
Gary
  • Replies 316
Posted Images
ive got a hpinabox gt30 with 70comp cover and .63 a/r internally wastegated and it is actually put together by gcg turbos. as for power i got 260rwkws at 20 psi. now my engines is almost fully rebuilt with tomei pon cams i will let you know how it goes. please dont critisize a product that you havent even road tested.
Hi. This is directed at BigCarl, I tried to PM you but it said that your PM service was not setup & that you did not have permissions to PM???
Sorry, I know this is off topic a bit but I cant contact BigCarl any other way...
I noticed that you have a hybrid GT30 with the nissan RB exhaust housing. I wanted to ask you if you used the hpInABox oil/water kit?
I have just ordered the same turbo with the oil/water kit and was wondering if there was anything else that I would need to fit the lines? The guy at HpInABox said that the oil line should be fine but the water line on the engine side might not fit & that I would have to get a nother fitting for that side of the line.
Also did you use the waist gate actuator that they supply? If so how hard was it to modify to fit?
Any tips on fitting this turbo (from anyone) would be a great help.
Thanks in advance
Andrew....
Thanks in advance
Andrew....
yes purchased oil and water lines from hpiabox ,my mechanic used some fittings from standard turbo to fit waterlines. if i had my car id take some photos but still having new motor fitted and run in e.t.c. but could take some photos next week.
thanx cube, just is a real mission to find a turbo of the single T VG30 every wrecker on the coast that i have rang hasn't got one and says goodluck finding one, rare as rockin horse sh**
sweetr33, my brother's friend might have just the exh housing for the vg30 left in his garage but need to clean up to find it! if you really interested let me know. i will ask him!!
Thanks bigCarl:
I think I have it under control. If I can use fittings from the existing lines for the new lines then that would be great. What Did you do for the elbow out of the comp housing to the intercooler?
i used a ninety degree piece of 2.5 inch mandrel bent mild steel, utilising stock cooler pipeing and silicon hose. i think thay you can buy the ninety degree silicon hose but looks dodgy to me??? gcg sell it.
Thanks for all the info mate, putting her in this weekend :). I noticed that you said you were running 20psi, does that make the rubber piping from the AFM to your turbo suck inwards?? Or have you replaced it with a steel version?
How did you connect the 2.5 inch mandrel bend to the turbo, I dont think its 2.5 inchs?
Sorry about all the questions guys, I will stay on topic after this I promise ;)
Seems that for all the time and trouble a TT conversion is so much easier......unless a turbo lunches itself and eats the front 3 cylinders. Also works out to about the same cost for a diy job.
I've measured the Comp wheel and taken pictures.
From my measurements (not really sure what to measure) the smaller top part of the comp wheel measured up at 46mm.
The larger bottom part of the comp wheel measured up at 63mm.
That would make the wheel a 53.3trim?
Trim = ((inducer)squared / (exducer)squared) X 100
Does garret list specs for this wheel?
The closest I can find to a 53trim is a TO4 54trim?
I will have a bit more of a look when I get some more time.
Nobody has them, and is they do, they want $600 for them
They were ~$250 until :) SOMEONE :angry: blabbed about how useful they were and then the price went up. :angry:
At least this time it wasn't me, unlike the R32GTST wastegate actuators, they used to be ~free until I opened my big mouth. :D
:angry: cheers :angry:
Thanks for all the info mate, putting her in this weekend  :D. I noticed that you said you were running 20psi, does that make the rubber piping from the AFM to your turbo suck inwards?? Or have you replaced it with a steel version?
Sorry about all the questions guys, I will stay on topic after this I promise  :)
That pipe sucks in for me at under a bar.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
