selling my cusco 2-way diff, 4.1 ratio, excellent condition, in R33 Housing, just bolt in. Also fit R32 if you swap the rear hats over and use different bolts, simple.
An absolute must have for any budding drifters or any high powered skyline still using the standard lsd!
in adelaide
$990ono
*** Diff was sold but buyer ran out of funds at last minute :chairshot
https://www.sau.com.au/forums/topic/78986-cusco-2-way-a-must-have/
hi greg, im no diff expert but ill tell you what i know...
The main benefit over a std viscous centre diff is that you will NOT get any open wheeling business. When you bag it or spin the wheels you get consistent 2-wheel drive. This will improve launches. When exiting corners same deal. I found the back end to be infinitly more predictable and controllable when on the slide/power oversteer, over the std diff (my stocky diff used to lsd on-and off a bit).
2 way means it locks under acceleration and deceleration, where the 1.5way locks only under accel. From my own experience, the back end is far more controllable on the limit, and when the tail gets out too far and i back off suddenly, it straightens up whereas with the stock diff it would do a 180 spin much more readily.
the only time you know its not a stocker is that when turning slow tight corners you will get some clunking as the diff locks/unlocks. but give it some gas and you get a very nice spin turn :D
i was asked to hold it until tuesday but havent heard back from the buyer as yet. if not confirmed by monday then it will be available.
by the way does anyone know the weight of an r200 diff and housing? my scales have gone missing. im guessing ~30kg?
cheers
This diff is now available again. Sale not successfully completed!
by the way, diff and housing weighs in at 35kg, from recent enquiries for the unsuccessful sale melbourne buyers are looking at just under 50$ for shipping to Brunswick bus depot.
cheers
its an r200, from what im told, you will just need to use the 2 main diff bolts from an r33, and swap the rear hats over. Which is what the r32 buyer was going to do.
the new diff im using now is from an R32 and im told they are same as s13. All i did was use 32 diff bolts and a r33 rear hat and it bolted straight in no fuss.
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
