3 standard rims. Very little tyre on two of them and not too much on the other. Average condition. Not too fussed about price. Have been sitting around for ages just make a reasonable offer.
Pick up only.
if no 1 wants em can i take em 4 free... i can pick up
https://www.sau.com.au/forums/topic/79018-r33-gts-t-rims/#findComment-1442286
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
