Hey everyone,
Just recently had the fuel pump fixed in my R30. Thought all the problems would be over. When the pump was not connected to the fuel line, it pumped out petrol. When it is attached to the fuel line it still pumps, but nothing seems to get to the engine. You can see the petrol in the fuel line, just before the fuel filter. I took the filter out, and you can blow through it. What would this be? I don't know much, but it kinda sounds like the pressure isnt big enough or something. If anyone knows or has had this problem, I would be happy to hear about it.
Thanks
Adam
https://www.sau.com.au/forums/topic/79035-fuel-pump-again/
It sounds like the metal line that runs under the car may be pinched / blocked.
Have a careful look at the condition of the line, from fuel pump to fuel filter. There may be some metal shields in the way - remove them. Spend the 5 minutes to do this properly. What you would be looking for is any sign that the metal line has been crimped (from a rock, jack or the like).
All looks good? Disconnect the hose from the fuel pump and disconnect the fuel filter and blow through the pipe from the engine bay end. First, fuel should run out of the line of its own accord. Blow through the line from the engine bay end, just to be sure. There shouldn't be resistance. If it feels like you are blowing up a balloon, you have your answer. Oh, and it would probably be the reason that you old pump karked it too...
https://www.sau.com.au/forums/topic/79035-fuel-pump-again/#findComment-1442378
Have you tried with the fuel hose disconnected from the fuel rail?
I recently replaced mine, and it took quite a while to get fuel at the fuel rail. I disconnected the hose from the rail, and had to do several "primes" of the fuel system (just switch ignition to ON, you get that initial 5 sec running of the pump, then OFF / ACC, then back ON).
https://www.sau.com.au/forums/topic/79035-fuel-pump-again/#findComment-1443814
Hey Guys,
Found out the problem. Had a mate comeover, after scratching our heads for a while :bonk: , we decided to place the pump right near the motor. Anyway it turned out to work. The fuel pump is working, but does not have enough pressure to reach the engine. So have to buy a new fuel pump......
ADAM
https://www.sau.com.au/forums/topic/79035-fuel-pump-again/#findComment-1454409
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
