Hey all
I own a 95 r33 gts25t. I currently have TEIN Type HR adjustables instaleld and i find them to be way to stiff for the sydney roads but they are fine on th highway.
Cause i do a lot of city driving, i want your input on a set of new springs and struts. Any feedback from your experience would be great, what im looking at getting is something with a good ride quality and good handling and what you paid for yours? and possibly any combos such as KYB and king springs etc???
Thanks
Rob
Just grab some 200 front and 150 pound rear springs, If the HRs are in good condition then i would hope they would be ok with a far softer spring. You can buy Bilstein springs for abotu $150 each, adn i understand Eibach springs go for about the same...may help!?!?!?
Do you know where i could find some 200 pound and 150 springs? or would i have to get some made up.
My rear strust seem to be making some rattling noise while driving over dumps. not always but sometimes, im thinking its either lose or their stuffed
What type of Bilstein shocks should you get?
There a few on the catelogue, a part number would be great.
What progressive rate spring should you recommend? Are kingspring low's progressive rate, what bilstein sping do you recommend,.
Heasmans at Sydenham are Eibach agents, they have most spring rates in stock. They can also check the shocks and they have a shock dyno if you want ultimate testing.
:P
hi, i have been told i need to get new shocks and springs 4 of, could you guys give me a list of good ones that are ok for road driving and are a little stiff but not bone shaking and are priced well around the 600 to 700 pounds mark, not to sure what that is in dollars, cheers , r33 gts-t. :confused:
You will hear the rear dampers alot more than the front as they are in the car with you. I had pillow ball upper mounts on my set of Tein HA and they were a little noisey. You also get more spring noise with the a/m susp ive noticed. Stick with the Tein's just soften them up.
Teins = Own league = On rails!
I have what SK suggests
The Bilstein shocks and Whiteline springs
Did alot of searching for prices and found Unique Autosports to be the best
I still have the receipt in my pocket...so here's my prcies (be warned though, UAS i think have raised em a bit since)
4 Bilsteins at $225 each - $900
Whiteline lowered springs $225
Sub Total $1195
subtract 10% for being a SAU member $119.50
TOTAL $1075.50
Good luck in the hunt :)
I am thinking of going 300lbs front and 250lbs rear springs on mine.
Anyone got similiar spring rates on theirs? I finially got adjustable front/rear swaybars going on also.
King springs want $250 for the pair custom made. Some people say king springs are rubbish and to get some koni ones instead??
R33GTR or R33GTST?
What are you going to use the car for?
Normal road tyres, or R's, or slicks?
What tracks, if you are doing circuit work?
Any drag at all?
For circuit work we find using more than 200 lbs rears is only necessary on tracks where we run 450 lbs in the front. Philip Island being the highest spring rate we use. I can't imagine needing more than 200 lbs on the road and for drag use closer to 150 lbs is better for launch grip.
R33GTR or R33GTST?
Any drag at all?
GTS-T
It will mainly be used for track as I now have another car as a daily driver.
Tracks will be PI, Sandown, Calder and Winton.
Will be using hankook silica 104 for now and then semi comps when the bank account recovers.
There might be a few drags in there but I cant see myself forking out more $$ for nittos just for the drags.
