Does anyone know the backlight colours on these items:
- Nismo's white face 320km speedo cluster
- Trust white face boost gauge
I know Apexi Boost Gauge has blu-ish backlight colour, so if Nismo speedo has the same blu-ish backlight colour, then it will match Apexi perfectly. Not sure about Trust boost gauge.
https://www.sau.com.au/forums/topic/7905-nismo-white-speedo-backlit-colour/
thx nissaner...
so trust boost gauge is definitely DOES NOT have blue backlighting, right?
Cause I wanna match the colour white face when it's off (daylight) and the colour of backlighting when it's on (night time)
they match ok in daytime but not at night Apexi whole face lights up pale blue nismos face is dark at night with only the numbers and logo + pointer and a fuzzy ring around centre lighting up . Nizmo looks good at night and I don't mind the mismatced Boost gauge 'cos it's off side in a pillar mount
http://members.optushome.com.au/jay51/our%...5-32/Instru.JPG
I'm sure you can replace the bulb that illuminates the speedo, etc.
How difficult is it to change actually? I don't mind the standard look dials, but they could do with a more interesting light colour.
I can solder in something else easily enough.
Originally posted by R33-JET
nismo dash is sexy at day and all
but at night it lacks to light up all that good
sometimes u cant even make out the numbers
only my opinion
also have new apexi electrical gauges that light up mad blue
which look crazy at night
First, I won't be doing much night driving, mostly day only.
So white face nismo will look great at daytime when I do my driving most.
Secondly, the nismo speedo lights up in greenish backlit, so I won't buy Apexi boost gauge coz I don't want one thing light up in blue and don't match up with others. So I will go with Trust white face boost gauge, which has the similar colour with Nismo backlit at night. I'm sure someone mentioned this in other thread I can't seem to find which one again.
Anyway, my car's wine red so theme-wise I don't feel it will match well with apexi's glowing blue lights at night... so my choice are fix: Nismo speedo & Trust gauge combination... thx everyone for the input.
Hey Jay...
Does your Nismo speedo cluster comes with all the warning lights like ABS, HICAS,etc? Since it is meant to be for a GT-R, if installed on a GTS-t, will the ATESSA (4 WD system) warning light comes on????
RS73 - I wanted to match my nismo white faced gauges to a boost gauge so I got the Trust one and yes they match.... almost identical. Have a look...
only my opinion
Not to be rude but I think that the nismo dash is crystal clear at night and better than the standard gauges. ALso if you look at the pictures above even in the VERY BLURRED background image of the dash I can make out the numbers. I've had the nismo ones in pretty soon after I got the car and they are clearer than almost any other car. Like RS73 I didn't want green gauges and blue light cos it looks like a circus.
As far as I know all nismo dashes for the R33 GTR are the same except for the white/black combos. And no the warning light does not come on because I believe its for the Active LSD (correct me if I'm wrong) which is only for the Vspec GTR.
thx 400hp, I've been lookin for that pic somewhere.
I can't think where you put your boost gauge....
pillar mount should be on the right, or you mount it somewhere to the left of the steering wheel?
Or your car is left hand drive?
Nah my car is right hand drive... I'm in Sydney dude :P
The boost gauge is mounted on the steering column covering part of the speedo. I don't really care as it only covers 220km/hr - 320 which you won't see often in Australia anyway... I thought about it heaps where i was gona mount it. I didn't wanna get defected for the A-pillar and didn't want to drill. Anyway I'm happy with it.,
u have to pull out the whole dash console to get to the bulbs!
rs73
if u want the apexi boost gauge to match your dash get the EL dash kit like mine.
INASNT,
I'm after the 320km/h speedo from Nismo, which has greenish colour backlight (the numbers only). So Apexi EL gauge is out of the question, and I am going with Trust gauge as the backlight colours match the Nismo speedo nicely as shown by 400HP's picture above....
Originally posted by rs73
INASNT,
and where exactly are you planning on doin 320km/h?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
