ok in the pic below notice the bulge in the cam gear cover to the left of the CAS (crank angle sensor), behind that bulge is the hub for the VCT
Now if you check the pic below of the RB26 clear cover it does not have that bulge, so adapter or no adapter it will never fit on because it does not have the space for the vct hub
Variable cam timing (VCT) for the inlet cam, switched using oil pressure.
I'm thinking a piece of mdf with a hole in it and a heat gun and the original cover may do the job.
Use the original as the base, cut away what is not able to fit. Start with gradually heating the area you want to deform then lay it over the base. Use the mdf with the hole (or a thick wool lined set of riggers gloves) to form the clear cover over the bulge.
Basically there is nothing to see with a RB25 so why bother?
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
