Hey all
I got 3 roll cages still for sale. My phone screwed up over the last 2 days so anyone who called me or mesages me i am sorry but if you are still interested you will have to get in touch again.
I have 3 roll cages that i dont need.
One is from an R33 and the other two are from r32 GTR's.
They are all 6 point cages with cross bar in back.
2 of them have complete padding and the other has padding in the rear section.
Asking $600 each. They are all in perfect condition want to get rid of them
easy to stick in they bolt into the floor and all the bars bolt up.
all good cages
I think that the gtr cages will for into r32's as the inside dimensions are the same (I was under that impression if I am wrong please correct me)
Call me on 0408064230 or e-mail: [email protected]
Thanx all
https://www.sau.com.au/forums/topic/79078-roll-cages/
Hey all
all good cages
Thanx all
interested in cage for 32 tried to contact but phone off please give me a call lucas 0402 613 997
https://www.sau.com.au/forums/topic/79078-roll-cages/#findComment-1443305
Hey this is fate, i brought a full cage for my r33 a while ago but it didnt fit because i have a sunroof, the roof liner is tons lower because the sunroof. Looking at the pics the r33 cage you have is is a r33 with a sunroof, so the cage you have is no good for someone that doesnt have a sunroof in there car. I have a cusco 6 point blue padded one with the rear angle piece.
Can we work something out ?
Does anyone with an r33 that doesnt have a sunroof want to buy his rollcage and swap me for my cage that suits a non sunroof car ??
Damn i want the cage so bad..
My phone number is 03 5335 9168
https://www.sau.com.au/forums/topic/79078-roll-cages/#findComment-1451689
Yea mine does have a sun roof but it would still be ok for someone without a sunroof but maby we can work something out I will pm you mate.
R33 cage still for sale!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/79078-roll-cages/#findComment-1453721
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
