hey guys,
for the past 2 days, ive been cleaning some big mess of wires under the carpet and seats of my car.
guess at one point it had some major audio system on it and the owner never botherd to clean up, so i come & try to install a head unit with some rear speakers and i had to deal with a whole shitload of lose/cut wires!:(
i started it finaly after a few cranks "which is odd" but didnt think of it,i take it out and went for dinner, everything is ok as usual.
later on on my way to home, it almost stalled,the car doesnt have the same power at all and its sound changed to poping and metel-like rumbling.. barf!!
parked it home, turned it off and on again, still the same..
i checked the i/c piping,nothing! :confused:
here is a video, sorry its realy bad, but u could still hear it
http://www.megaupload.com/?d=247DTZ2A
it is stock by the way only an intake & a cat-back "and been runing rich like a MOFO!!:bonk: "
any ideas?
thanx guys,,
  • Replies 57
Sounds like one or more of your spark plugs have fouled up. It happens when your car runs rich or you have been idling a long time. Remove all 6 and check which ones are really black, you'll spot it.
Replace those ones and while they are all out make sure the gaps are correct.
Refit the plugs & she show be sorted out.
spark plugs??
but i didnt even put 100 klm on em they r new ngks and gaped to 0.8
btw...
you got the sweetest car!
I HATE YOU!!
Thanks for the complient - I think.... :confused:
Could you of cut some wires that you shouldn't have, maybe a sensor wire, ground wire or something. Must be sure of this.
Usually your sort of problem happens with fouled spark plugs. Couldn't hurt to check cause I dare say one or more are all fouled up.
:uh-huh: :wassup:
will do! :(
now that i think about it, am almost sure it has to do with the wires, coz it was runing flawlessly b4 "except for the runing rich part!"
the thing is.. i wouldnt know where or what to look for!!! coz i had all boot lining,half of the dash, front & back seats out, and the carpet on both sides!!
Start at 1 point and slowly go through any wire you could of touched. Any cut off wires, make sure you know what it is for. You must be patient. It's going to take a while especially when your surpect of some wire and have to find out what it is.
But think of it this way, if you get someone else to do it, imagine the bill......#$#$.
There is an all workshop manual that can help you out for things like this.
Eventually you will find it and all will be good.
Good Luck
P.S. Still check the plugs though, before anything, easier to start there, then going through all your wires.
also check all of your coils... I'm not sure of the set up of yours but some are prone to cracking if you overtighten them... also if you changed them 100k's ago, is there any chance of water ingress etc?
things like this suck, it could be wiring, or it could be coincidence that it just happened after you were playing! good luck with it dude.
I agree with wet, check the easy (simple) things first!
thanx for the input guys..
i 4got to mention that my new rear speakers stoped working , and am sure they were fine some time last night, b4 this shit happend! talk about a coincidence!
am going to check that 1st, even though i dont see any connection!
ok, its 4:19 am over here, and just took my plugs out..
cant tell if they're good or bad for shit! am bad at this..
are these what is causing this problem??
all tips are fine, only some discoloration on # 1 & 4
also, my bro is the one who gaped them, to .7 not .8 like i asked him,
said its not a big difference.
so now am just gna be waiting for help so i coud go back out side.
aint sleepn with my baby all opend up! :gaga:
Hi there,
OK, no.1 looks fouled, I can't see no.6 but no. 4 looks ok.
I see that you got the NGK BCP7E-11. In future get the BKR6E. The 6 means a hotter plug & better burn. These are also the ones I run in my car. The -11 means that at factory they were gaped at 1.1 so even if you got the BCP7E they would of been gaped at .8 & gaping them means a small bend.
If all was good & you have just recently installed these (100km ago) they should have looked exactly like 2,3.
It's up to you what you would like to do, but trying a new set of plugs is a good start & even if it's not that, well you'll have them just in case you foul any plugs (happens to Skyline alot) and they'll be there for your next service anyway.
Now your plugs are out, check all your coils for any cracks, examine closely.
heyyy! THE PIC IN UR SIGH ON THE RIGHT ISNT UP THERE!!
NOT FAIR!
I was in a rush, but your right, bad angles. I thought my pic of signature was in my photo's, I just checked - its there but it bigger
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
