HELP! R33 GTR Poping awfully weird.. *video*
GTR4ever
 Share
hey guys,
for the past 2 days, ive been cleaning some big mess of wires under the carpet and seats of my car.
guess at one point it had some major audio system on it and the owner never botherd to clean up, so i come & try to install a head unit with some rear speakers and i had to deal with a whole shitload of lose/cut wires!:(
i started it finaly after a few cranks "which is odd" but didnt think of it,i take it out and went for dinner, everything is ok as usual.
later on on my way to home, it almost stalled,the car doesnt have the same power at all and its sound changed to poping and metel-like rumbling.. barf!!
parked it home, turned it off and on again, still the same..
i checked the i/c piping,nothing! :confused:
here is a video, sorry its realy bad, but u could still hear it
http://www.megaupload.com/?d=247DTZ2A
it is stock by the way only an intake & a cat-back "and been runing rich like a MOFO!!:bonk: "
any ideas?
thanx guys,,
  • Replies 57
Sounds like one or more of your spark plugs have fouled up. It happens when your car runs rich or you have been idling a long time. Remove all 6 and check which ones are really black, you'll spot it.
Replace those ones and while they are all out make sure the gaps are correct.
Refit the plugs & she show be sorted out.
spark plugs??
but i didnt even put 100 klm on em they r new ngks and gaped to 0.8
btw...
you got the sweetest car!
I HATE YOU!!
Thanks for the complient - I think.... :confused:
Could you of cut some wires that you shouldn't have, maybe a sensor wire, ground wire or something. Must be sure of this.
Usually your sort of problem happens with fouled spark plugs. Couldn't hurt to check cause I dare say one or more are all fouled up.
:uh-huh: :wassup:
will do! :(
now that i think about it, am almost sure it has to do with the wires, coz it was runing flawlessly b4 "except for the runing rich part!"
the thing is.. i wouldnt know where or what to look for!!! coz i had all boot lining,half of the dash, front & back seats out, and the carpet on both sides!!
So you just changed the spark plugs? maybe you stuffed something up with them? Check them anyway. Or could be something you did when cleaning up wires. Good Luck :(
Start at 1 point and slowly go through any wire you could of touched. Any cut off wires, make sure you know what it is for. You must be patient. It's going to take a while especially when your surpect of some wire and have to find out what it is.
But think of it this way, if you get someone else to do it, imagine the bill......#$#$.
There is an all workshop manual that can help you out for things like this.
Eventually you will find it and all will be good.
Good Luck
P.S. Still check the plugs though, before anything, easier to start there, then going through all your wires.
also check all of your coils... I'm not sure of the set up of yours but some are prone to cracking if you overtighten them... also if you changed them 100k's ago, is there any chance of water ingress etc?
things like this suck, it could be wiring, or it could be coincidence that it just happened after you were playing! good luck with it dude.
I agree with wet, check the easy (simple) things first!
thanx for the input guys..
i 4got to mention that my new rear speakers stoped working , and am sure they were fine some time last night, b4 this shit happend! talk about a coincidence!
am going to check that 1st, even though i dont see any connection!
ok, its 4:19 am over here, and just took my plugs out..
cant tell if they're good or bad for shit! am bad at this..
are these what is causing this problem??
all tips are fine, only some discoloration on # 1 & 4
also, my bro is the one who gaped them, to .7 not .8 like i asked him,
said its not a big difference.
so now am just gna be waiting for help so i coud go back out side.
aint sleepn with my baby all opend up! :gaga:
Hi there,
OK, no.1 looks fouled, I can't see no.6 but no. 4 looks ok.
I see that you got the NGK BCP7E-11. In future get the BKR6E. The 6 means a hotter plug & better burn. These are also the ones I run in my car. The -11 means that at factory they were gaped at 1.1 so even if you got the BCP7E they would of been gaped at .8 & gaping them means a small bend.
If all was good & you have just recently installed these (100km ago) they should have looked exactly like 2,3.
It's up to you what you would like to do, but trying a new set of plugs is a good start & even if it's not that, well you'll have them just in case you foul any plugs (happens to Skyline alot) and they'll be there for your next service anyway.
Now your plugs are out, check all your coils for any cracks, examine closely.
heyyy! THE PIC IN UR SIGH ON THE RIGHT ISNT UP THERE!!
NOT FAIR!
I was in a rush, but your right, bad angles. I thought my pic of signature was in my photo's, I just checked - its there but it bigger
nope! not the one on the right.. cant find it!:confused:
 Share
    • Hi and welcome. What are you planning to do to the car or will you keep it stock?
    • https://windowmotor.com.au/collections/02-07-v35-nissan-skyline?srsltid=AfmBOorAnTNYaD1tXzczAKZFqnDkZy23WgPXNfVscyeRKHhVNkiaC-WH https://www.gumtree.com.au/s-v35+stereo/k0
    • Heaps of historical info on this, a quick Google gave dates back to 2012, all talk about identification markings, dimples, shapes of mounting surfaces, washers, that are concave or something to match the fasteners mounting surface, which ARP states that if the washer, if it uses a washer in its application, isn't the right way around, it can cause premature failure,  even if it was torqued up correctly with whatever lube is meant to be used There is even talk about getting the bolts Xrayed to check the structure, one was about some builder getting multiple sets of bolts, having them Xrayed, and picking from those results Nowadays identical "looking" fake parts, in identical looking fake packaging are everywhere, with all the markings and stuff, the only way you know they are not legit is Xray or when they fail I assume if you don't want fake parts, and don't have a Xray machine handy, is to get them directly from ARP in the USofA, aftermarket rod and head bolts aren't something to take for granted  Imagine building a big dollar build only to find you lunch it because of an inferior fake fixture let go 😫
    • Quick update team on the build Things done. Installed Diff Brace ( TMR Performance ) Removed Steering Rack and replaced bushings with GK Tech bushings Remove Manifold and replaced Rocker Cover Gaskets and the Spark Seal Tubes Installed 1000CC Bosch Fuel Injectors Installed R35 Spark Plugs ( Pre-gapped to 0.28"  Installed Z1 Coilpacks Removed Fuel Sender unit and modified OEM pump to fit the 350lph Fuel Pump Installed Fuel Sender unit back with a Fuel Return system ( TMR Performance Fuel Return V2 )  Setup Fuel Lines that were AN lines and used P-Clamps to secure them to body ( This is needed to make this road legal in NZ ) Setup Fuel regulator Setup Vacuum lines from Wastegate to boost controller ( 3 port mac valve ) Wired boost solenoid to the EVAP sensor ( Behind manifold of car ) - Polarity of cables doesn't matter Setup BOV and Fuel Regulator lines Installed both aftermarket Aero Fenders ( Sourced from Japan ) Received Impul 280km/h Speedo ( Sourced from Japan ) Installed Carbon shift console Drive down the road untuned without creating boost pressure to test for leaks ( Video attached ) Setup JRP Racing 14in1 Gauge with Boost pressure being monitored Buttoned car back up and Tow to tuning shop in the mighty DE ( Nissan Elgrand E51 ) - VQ35DE Tuning platform is EcuTek and am hoping to 550WHP ( Dyno day is 9th and 10th of October )  Had Shop weld in a new Exhaust piece to connect Downpipe > Motordyne Resonator and to add x2 02 Sensor bungs for an AFR Gauge that will hook into the JRP Multi-Gauge    20240927_181518.mp4 20240927_181618.mp4 20240928_192844.mp4
    • It's in the bloody domain name twice! Yes...the GTR boxen have, for some reason, been cheaper than the RWD boxen for a long time. 10 years ago the GTST box was available here for <AU$3k. 5 years ago the GTT box was available for ~AU$3300. Both retail through 3rd party. Now the GTT box is >4k locally and only available for less if you're willing to jump through some hoops. Apparently they can be ordered from Nissan dealers for $3-3.5k at trade pricing. A friend of mine has a new GTT box sitting on his showroom floor that I keep wanting to hit him up for but I'd somewhat rather he sold it to someone else at his asking price than to me for a mate's rates discount.
