hi, it sounds a bit worse than it should be. When the VLs came out in NZ you had a choice of RB20E or RB30E, apparently the RB30 was more economical because you didnt have to thrash it to get any decent performance out of it. So it may not get as good as you would think for a non-turbo. My Turbo GTS4 gets about 350-400 around town on a tank.
what temp is it running at - i had a car with a stuck thermostat. Didnt warm up real quick and temp fluctuated on the highway - down to cold. New therm gave anoter 40km a tank
Just see where your temp sits.
Run some good injector cleaner (the concentrate) I tnink it is redex (about $12) but soes a lot of tanks.
Clean the AFM with contact cleaner. pump the tyres up.
There the cheap options...
02 sensor could be stuffed like baseliez is saying. you could replace that for about 50 or 60, may be wotrth it - unless you get exhaust gas analysis to see what AFR it is running at idle and part throttle
if temp remains at 1/2 most of the time then your thermo is probably ok.
Other things to change -
fuel filter,
and possibly air filter and spark plugs.
02 sensor more likely though.
I dont think the responsiveness has much to do with it unless you are driving it a lot harder
try some fuel injector cleaner.. I have always been dubious about them, but after replacing everything else, and the o2 sensor.. injector cleaner *seems* to have made the biggest difference.
Gone from about 350 a tank, up to 500 a tank, mix of city and highway driving... all with a bottle of injector cleaner. That is pretty much going from 15L/100km back down to 12L/100km(!). This is on an RB20DET, and I am usually fairly heavy footed.
managed to get 600km (1/2 highway driving) out of R32 gtst sedan with stock rb20det (cat back exhaust and filter panel), so 550km in ceffy is quite possible??
600km was done with never reving it past 3000 rpm, keeping it off boost :rant:
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
