hi, it sounds a bit worse than it should be. When the VLs came out in NZ you had a choice of RB20E or RB30E, apparently the RB30 was more economical because you didnt have to thrash it to get any decent performance out of it. So it may not get as good as you would think for a non-turbo. My Turbo GTS4 gets about 350-400 around town on a tank.
what temp is it running at - i had a car with a stuck thermostat. Didnt warm up real quick and temp fluctuated on the highway - down to cold. New therm gave anoter 40km a tank
Just see where your temp sits.
Run some good injector cleaner (the concentrate) I tnink it is redex (about $12) but soes a lot of tanks.
Clean the AFM with contact cleaner. pump the tyres up.
There the cheap options...
02 sensor could be stuffed like baseliez is saying. you could replace that for about 50 or 60, may be wotrth it - unless you get exhaust gas analysis to see what AFR it is running at idle and part throttle
if temp remains at 1/2 most of the time then your thermo is probably ok.
Other things to change -
fuel filter,
and possibly air filter and spark plugs.
02 sensor more likely though.
I dont think the responsiveness has much to do with it unless you are driving it a lot harder
try some fuel injector cleaner.. I have always been dubious about them, but after replacing everything else, and the o2 sensor.. injector cleaner *seems* to have made the biggest difference.
Gone from about 350 a tank, up to 500 a tank, mix of city and highway driving... all with a bottle of injector cleaner. That is pretty much going from 15L/100km back down to 12L/100km(!). This is on an RB20DET, and I am usually fairly heavy footed.
managed to get 600km (1/2 highway driving) out of R32 gtst sedan with stock rb20det (cat back exhaust and filter panel), so 550km in ceffy is quite possible??
600km was done with never reving it past 3000 rpm, keeping it off boost :rant:
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
