I think some of these may be quite hard to come by, but I thought I'd try my luck here before sourcing out some third party items.
I'm looking for (all for Series II):
1: Series II passenger side headlight cover
2: Driver-side rear vision missor - preferably sonic silver
If anyone has any (in good condition) feel free to PM me. I'm happy to pay postage.
https://www.sau.com.au/forums/topic/79089-wtb-r33-series-ii-accessories/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
