246 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 86
Manual for me, its more fun, and i think you have more control over the car, around corners, how you want to power your car, and you just have more feel for the car, i've had 4 cars, 1 auto, it was a v8, so yeah ... ill always love my manuals, well until i am like 60 and just cant be stuffed !
Manual because I feel like im in control of my vehicle.
I had an Auto R33 "Not knocking Auto R33's at all but It just felt like it was missing that sports car feel" Id go an auto next time because I sit in traffic for an hour on the way to work and a hour on the way home every day.. problem is on the weekend Id rather my Manual !!
nothing but manual :(
i agree with the comment above about being able to have more control over the car
but also i think people who learn to drive manuals from square one are much better drivers then people with a steering lisence (read: auto)
*runs and hides*
lol Mark. Let the flamming from the Auto drivers begin :(
I used to drive an Auto VL. Couldnt stand it, boring to drive and i just could not be bothered. Plus i love ripping launches from like 5000-6000 RPM :(
Go the manual.
On the other hand, Auto is mad for traffic. It justs depends on your ruote and what would be more comfortable for you.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
