Hi guys,
My oil pressure is suddenly way lower than it should be.
Previously, if i'd turn it on, the oil pump would pump it straight up and the oil pressure guage would read 4.
Now, however there's problems. The engine starts, oil pressure comes up to 4, but then drops way down after a few minutes. It idles at less than 1 on the guage, and when reved it doesn't come up to more than 2.
Any help as to the reasons much appreciated... Sam
hoping it's not the oil pump.
ps. i noticed the problem after just getting onto sandown, turned it straight off and got a towtruck home to be safe :( lousy day that was.
https://www.sau.com.au/forums/topic/79107-oil-pressure-in-rb20det/
that's normal afaik. mine reads 4 cold idle, but driving normally sits at around 1.5-2ish and sits really low when stopped at lights. i've been told higher than 2 is bad once the car is warm.
there is a red light that comes on which is the oil pressure warning light (it comes on when u start car for a second or two). i figure if that light's not on, all good!
also the stock oil pressure sender & gauge is crap, so go aftermarket if you want to keep a better track of oil pressures.
thanks for the replies lads. after researching, i'm pretty sure it's to do with the second number in the oil i'm running. i'm using 5w-30 ... if i were running an oil with the second number as 50, ie. higher viscosity at higher temp, it just might fix the problem. but seeing as the problem isn't really much of a problem, i'll leave it till next time.
oh and also... i think the reason this happened months after the oil had been changed was because the oil's molecules got broken down over time making it thinner when the engine was up to it's running temperature :bananaman
the nissan specified grade of oil is 7.5W30 so going to a *W50 is only going to 'mask' any problem (if there is one). I wouldn't go thicker than a 10W40.
ok, oil pressure around 1 bar at idle is no big problem but when driving along at say 3000rpm you should have pretty good pressure then. do you?
Otherwise it could be a faulty gauge.
indeed, i wouldn't put in 50 because it wouldn't get around the engine quick enough. the pressure guage does not necessarily correspond with oil flow either.
at 3000rpm i believe it was a bit under 2. it was just the idle pressure that worried me. next time i'll be using the nissan 7.5w-30.
yeah the nissan semi synthetic is not too bad. it's quite cheap but I would say it's fine for a stock/near stock car. dunno if i'd use it on the track though as it's film strength and high temp lubrication would not be as good as some of the higher priced stuff.
hmm, 2 bar at 3000 is a *bit* of a worry I would have thought 3+. i mean it is an RB20 so whats the worst that can happen? very cheap to replace. on the other hand if it is the original (un-rebuilt) motor then that is probably about right. on my RB26 (fairly recently rebuilt motor) the oil pressure when hot is well about 4bar at 3000rpm (off the top of my head) any lower than 3 bar and i wouldn't feel so good. it's an RB26 though...
Well I've been told that a low oil pressure at iddle when warm is indication of an old engine say 150Ks -200Ks, also that in a tight well preserved engine it should sit on 4 at idle when warm. :confused:
Mine sits at 3 or a bit lower than, when warm at idle, but when cold in the mornings it just jumps up to 8 for a good couple of mins, and gradually goes down as the engine warms up.
Im pretty sure the recommended oil pressures are in the engine manual?
When the car is cold it should read high at about 4 or so, but as the car heats up (and the oil heats up too and becomes less viscous) the pressure should drop again.
About 1 at idle, 2 at 1000rpm, 4 at 4000 rpm is normal i think?
i think before you start wondering what's wrong with your engine, get an aftermarket oil pressure gauge & sender, just to make sure it's not the stock sender which is providing inaccurate readings.
(actually, after driving the car this morning and paying more attention to the gauge, i'll revise what i said before. when warm driving at constant speed, it's usually on around 2.5-3ish.)
yeah we've been doing it against what's in the manual. we put new oil in today... thicker oil. on the first drive it was slightly better... but after a longer while it was much better and back to how it was before. happy days for now. we went to repco planning on getting 0w-40... ended up getting mobil 1 5w-50
well... most of the time since the change it's been fine, but once so far the pressure has dropped down to almost zero. so i let it sit there for a while watching it, drove off and it jumps up again and next idle it didn't drop back down. maybe the sending unit. we all have the same cars, same ages, same rate of failure.
next time it happens we'll tap the sending unit with a wrench and see what the guage reads
Oil pressure: Sender failure
Like all normal vehicles, good oil pressure is essential. The sender itself is located by the oil
filter on the left hand side of the block.
The following figures are the workshop manual specification for oil pressure on the
RB20DET...
1kg/cm2 @ 600 rpm
3kg/cm2 @ 2000 rpm
4kg/cm2 @ 6000 rpm
My own car has a oil pressure gauge that doesn't behave due to a fault somewhere, so I had a
check done by running a remote gauge which gave the correct numbers... Whew! Update: the
oil pressure switch replaced.
Thats from the The Sky is the Limit skyline book thats floating around www.skylinesdownunder.com and sau somewhere
hey mate another thing that you can have problems with is the oil pressure sender unit. When my car came over from japan it was fine then after about 3 weeks i noticed while i was driving that the pressure dropped to zero, Now if this happened it would have been game over for the engine so i knew the gauge reading was full of shit. I had the gauge tested an it was fine so we ended up tracing it back to a faulty sender unit... Another thing that can also happen i that the gears in the oil pump wear out which is much more costy to fix as you have to remove the sump etc to fit a new pump.
This comes up so often. Its pretty much guaranteed that MOST r32 oil pressure senders are up shit creek.
Mine works intermittently, sometimes sitting on 0 for half an hour, other times going up past 4.
Its basically a case of the light, if it comes on kill the motor! That is the most important part. The proof lies in the fact that after 7 months on the road my car has read zero sometimes and its still going strong.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
