When complied I guess the things get butchered, has anyone replaced them?
How?
The reason the Xenons are removed is that in some of the 34's they are 'Automatically' adjusted whilst driving. In other models they have a manual switch which can be adjusted by the driver. These are allowed. The auto ones are not.
Dave
Yeah thats what I mean, trying to find out how they were?
if there was transformers,ballasts,just bulbs? etc
I think most time they just change the HIDs with the sedan's non HID head lights.
But i have seen one where they open up the HIDs and take out the ballast and bulbs and replace with a normal driving light. BTW a proper compliance shop will distory all the HID things when compliancing. So to answer ur question, it prob be hard to find the original stuff in AUS. I think is cheaper if u just buy a new aftermarket HID kit and put in, is actually quite easy these days with the direct plug in type. ALSO the aftermarket ones is much much brighter then the stock ones.
I think the sedans have the same HIDs as the coupes. Both are available with halogens too. You really need the OEM lights as I've seen such terrible light patterns from kit upgrades on cars that weren't meant to have HIDs. I haven't seen one of these kits in an R34, but from what i've seen in Cefiros, Skylines and Supras, they look terrible and only give glare to oncoming traffic rather than decent lighting. I've got a pic somewhere on my computer of the light pattern from a kit. If I can find it I'll post it.
You should check mine out - they're crisp, non glaring and have a perfect cut off. There's some pics in the thread in my sig of both my car and my flatmate's 32.
If the r34 have projector lights like the r32/a31 then I would highly recommend the HID kits I'm organising a group buy for.
If they're "normal" looking lights (after the conversion back to halogen) then I would suspect they do glare and not cut off properly so I would suggest you find the OEM HID assembly and use that.
Good luck :P
Ricnismo ,
The balasts are underneath the light but they should have been removed , usualy cut off , sometimes just unpluged and removed . They should have inscribed on the top black plastic "H1 12V 55W " , thats to indicate the type of globes they have in there .
All gtrs and gtts come with xenons as standard , some none turbos and some sedans come with halogens .
Gtr xenons are reflectors not projectors , series III r33 gtrs have projectors but the 34 xenons are brighter .
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
