For normal driving around town the standard heat exchanger fitted between the engine and the oil filter is quite satisfactory. However, 3 or 4 times a year I take the car to Sandown or Calder raceway for a blast around the track. I remember running around Philip Island a few years ago with a mate in his R32 GTR on a mild day. Three or four laps of the track at wide open throttle (WOT) was enough to raise the oil temperature to over 130 degrees C and activate the oil temperature light. Three or four laps of Philip Island represents over 8 minutes of the engine under full load at WOT. This cannot be duplicated on normal roads for obvious reasons. Last March I ran the car at Sandown and the air temperature was 32 degrees. I figured 2 or 3 laps flat out would be enough to boil the oil! I didn’t have an oil temperature gauge fitted at that time but I imagined the oil would be very hot. Another factor to take into account is the engine is developing 220kW at the rear wheels, which means about 250kW at the engine. Thus an increase in power developed by the engine from 170kW to 250kW must transmit the extra heat somewhere!
Oil Cooler Kit
I purchased an oil cooler kit from Hong Kong over the internet for $400 delivered.
It also came with a remote oil filter mounting which was an added bonus!
Kit on the bench after it arrived
Fabrication the Mountings
Where to mount the oil filter and cooler? The reinforced hoses that came with the kit are way too long for the R33, thus a compromise on location for the cooler and remote filter had to be found to make the installation easy. For obvious reasons the cooler should fit in the driver side guard, near the vent on the series 2 front bar. First step was to remove the front bar. I fabricated an ‘L’ shaped steel bracket from my favourite shop – Bunnings. I also mounted an aluminium support bracket for the right hand side of the cooler.
Trial mounting showing L shaped bracket and additional support bracket made from aluminium. (Front view)
Trial mounting. (Rear view)
Oil Temperature Sensor Mounting
One of the objectives of the exercise was to reduce the engine oil temperature, but what was it? I had previously fitted a VDO oil temperature gauge, but I lacked a suitable place to mount the sender! I took this opportunity to mount the temperature sender in the remote oil filter adapter. It has two bungs for such a device. The thread was different, so I had to re tap the hole with the correct tap.
Remote oil filter with temperature sender fitted.
Remote Oil Filter Mounting
I looked and looked to find a suitable position to mount the remote filter taking into consideration the length of the hoses and I wanting the hose installation to look like a professional installation. I have seen many filters mounted near the driver side strut tower. Unfortunately the hoses are way too long for this. I found a suitable place down on the front chassis rail near the radiator and below the windscreen washer tank. This location, if you look carefully has two blind 6mm nuts attached to the chassis rail. I don’t have to drill any holes – beaut! I quickly made a bracket, now for the hoses.
Fabricated bracket attached to oil filter
Remote oil filter location
Attaching the Hoses
Remove the oil filter from the engine and attach the engine adapter. Make sure the two ‘O’ rings are in place. I used a little grease to hold them in place. Take note of the orientation of the engine adapter hose connectors, check the markings, inner and outer, this orientation will be required later. Outer is for the outside of the filter, and the other is the inner of the filter (threaded section). The oil from the engine is pumped through the outer of the engine adapter, through the remote filter outer (small holes with rubber one way valve), across the oil filter element to the inner threaded section of the filter, then to the cooler and returned to the engine via a long hose to the inner threaded adapter on the engine. If the hoses from the engine adapter are on the wrong way, the one way valve in the oil filter will prevent oil circulating through the filter and cooler. Take note of the orientation before you mount the adapter.
By the way the standard oil filter will not fit the new remote adapter because a different thread is used to attach the oil filter. An oil filter for a Commodore V8 will fit – Z160. I also sourced a Z30 which is physically larger filter and has a larger filter element. I will upgrade to the Z30. The installation of the hoses and attaching them to the fittings is a slow and time consuming job.
Oil filter removed and the engine adapter mounted
Hoses attached to adapter
Oil Cooler in place with hoses attached
Finished item from front of the R33
Starting the Engine for the First Time
Most likely the oil will require topping up with the addition of the oil cooler. Firstly, oil has been lost by removing the oil filter and we have now added addition hoses and cooler capacity that all requires to be filled with oil. Take this opportunity to do a complete oil change while the filter is off. Any way I estimate you will need about 4.8 litres of oil (a little left in a 5 litre container). Disconnect the ignition wiring loom on top of the rocker housing at the rear of the engine. We don’t want the engine to start just yet. Now remove the new remote oil filter if you have fitted it. Crank the engine for a few seconds until you see oil appearing at the remote oil filter housing. Remember the oil must appear around the outer gallery of the oil filter housing. If it comes out of the centre gallery, you have he pipes connected to the engine adapter the wrong way round. It is most important to get this correct before you go any further.
Oil should appear from the outer gallery
If all is OK, attach the new oil filter and start cranking again. This time we are cranking the engine to fill the new oil filter, the hoses and the oil cooler with engine oil. Keep cranking the engine until the oil pressure light goes out and the oil pressure gauge shows a reading. It is now safe to start the engine. Reconnect the ignition wiring loom and start the engine. Make sure you have oil pressure and this time check for oil leaks around the fittings.
Once the engine has warmed a little, check there is heat in the new oil filter and the oil cooler should be getting warm as well. If these are not warm or hot, you still may have the oil flowing the wrong way.
For normal driving in the cooler months I have fitted a cover to the oil cooler to stop airflow through the cooler fins. The engine oil temperature sits at about 70 degrees once warmed up. I am interested in what temperature the oil rears on the track now.
Cold Weather Covers
Melbourne’s winter is 10 to 15 degrees, so I figured oil cooler covers would be appropriate while the car is not on the track. I wanted covers that were easy to install and remove. I formed 2 pieces of aluminium in an ‘L’ shape to make a front and a rear cover. The size was 220 x 140 and 60 deep. The front cover has 2 additional brackets pop riveted to them to hold both covers in place. To install, I hold the rear cover in place and slip the front over to hold both in place.
Cold weather covers in place
Good luck!
Updates:
Oil filter types
Oil capacity
Cold weather covers
Updated thumbnails into article
Edited by Blk33
  • Like 2
https://www.sau.com.au/forums/topic/79130-r33-oil-cooler-installation/
BLK33:
Damn this is a good help to me.
I ordered my kit.....looks very close to yours.....the other day. Good to see it all fits.
A question i have is can ya install the oil filter upside down???
Or, with it like you have it, when you change ya oil filter, is there much oil left in it....As in when you unscrew it oil isn't just gunna piss everywhere??
BLK33:
I agree loosing the oil when the filter is removed is a pain! The oil filter holds oil up to the top of the threaded section the filter attaches to. Thus when the filter is undone a cm or so of oil in the filter goes everywhere. I just wraped a rang around the the filter to catch it all. Mounting the filter upside down would not pose any problems, just where to fit it! The braided hoses are difficult to work with. Post up addition locations to mount the filter when you get your bits.
Good effort mate. Pity the fittings are swaged on- I used speedflow stuff for my tt upgrade custom hoses. If anyone does get the urge to cut SS hoses, the best way is to wrap tightly with electrical tape, then position the location of the cut close to the jaws of a vice to hold it, then cut with a fine hacksaw blade. I go to HIS Hose in Somerton and the fittings are about $10 each.
Just a question with the engine adaptor. Is that a spin on (filter replacement) type or do you remove the existing plate?
Spin on engine adapter just like the oil filter. It has 2 'O' rings on the adapter to seal it.
Ok got my kit today....Just looking at it, my cooler doesn't have any mounting holes at all...:)
Ither than that, all looks the same, just mine doesn't have pretty blue fittings.
I might have to make up a bracket then zip tie the cooler to it or sumthing???
Anyone got any better ideas???
Ok, got mine fitted. Lots of fun :rant:
I've just zip tied my cooler to the body, so it won't move.
My oil filter is in the same postion as yours BLK33
I also got my mate who works for PIRTEK to come round and cut my hoses a bit and also give me some 45degree pieces to help.
Your instructions for the first start up helped a lot, thanks BLK33
Will post pics soon
Will post pics soon
That is a great idea Packy. I wondered about cuting the hoses and a adding a few more 45 deg bends. With the option of cutting the hoses and adding 45 deg bends, you could mout the filter upside down in another location on the strut tower. Do you know what PIRTEK charge per cut?
Look forward to your photos.
I have no idea what pirtek charge for cuts, it ain't much. The call out fee is $60.
They can make up braided hoses. The hose is $65 a metre fittings are around $15 each. If you take the sizes etc to their workshop its cheaper.
Here's some photos, i forgot to take a pic when i had the front bar off. Maybe another time.
Oh yeah, i also used the whole 5 litres of oil in the car too.
Now to install my coilovers today :rant:
Well done on such an excellent install guide - good work!
Ive got one of these kits in my series 1 aswell.
I mounted the core inbetween my radiator and front mount.
I chose this spot as it should still get cool airflow and should be right in the cooler months aswell.
Its also well protected from rocks etc...
Eventually I will get a mist kit for the front mount and oil cooler.
I had top and bottom brackets made up to support the core. (couldnt get pics of the bottom one)
I also mounted my filter at the same position the fuel filter bracket is mounted at.
This was installed without any drilling. I like how youve mounted your filter better though. Think I will do the same eventually.
I dont have an oil temp gauge so I am unable to monitor temps at the moment.
Once again, good work mate.
:D
all looks good as im thinking of getting a cooler soon.
I dont understand the weather covers though?
What are they for?
Thanks, and Well done on the guide
When you don't have a thermostat your oil cooler always has oil going through it. When it's cold and you're trying to warm your engine up, or when it's just really cold your oil is always getting cooled.
You don't want this because your oil can actually be too cold.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
