just reading this other thread about how long people warm up their cars b4 they start driving...
i was wondering how long people leave their turbo timers for?
and also how did u by pass ur immobolizer or u just wait around?
i normally set mine on 15secs after normal driving around and about a minute if i gunned it : abit.
i got the Mongoose 3point alarm imobilizer which work in conjunction with my turbo timer.
https://www.sau.com.au/forums/topic/79152-how-long-u-cool-down-for/
I look like a fool because i cant lock my car untill the engine shuts off. Im just hanging around my car for 30sec untill it turns off. I would use the Auto feature on my TT if i could lock the car and leave it. Auto normally does around 4 minutes...
15 minute warm up jesus you will be causing more wear on the engine then doing good i reckon. i normally let it warm up for a minute or two then just keep the rev's under 3K and try to keep off boost as much as possible till the oil preasure starts to drop down to the wamr level.
i warm my car up for 15min and leav turbo timer on for 5, neighbours get the shits but hey what can you do. my theory is if they complain smash their windows, if they call the cops get your mates to burn their car.
thats too ridiculous for words
anyway getting back to planet earth
as said before
dont drive hard for the first 5 or the last 5
my tt is always set for 10 seconds
That's ridiculous.
15 minutes is too long
If they're windows or car was smashed they'd narrow it down to the knob who's car is always running with no-one in it.
cool down here not warm up...
so most people wait around till their TT turn off before locking the car?
i agree with what others have said in terms of cool down really a turbo timer may not really be required if you just drive normally for the last 5 minutes or so. I have a turbo timer though for the times that i am in a bit of a rush its set to i think 30 - 40 seconds.
Its crazy to be running the car so hot up until you stop that you have to use a turbo timer at all. Its not just your engine, you need to think about brake temps warping rotors etc.
Just drive it slowly for the last 60 sec of your trip, lcok the car and wander off.
The only time a TT should be used is when you have just finished a session on a race track.
My car has done over 100,000km i dont have turbo timer and never let it cool down if ive been driving normally, if ive given it a hit then come to a stop (hardly ever happends) ill give it a couple of minutes. everything still seems to be fine! I agree just take it easy for the last minute or 2 of your drive.
So far just been taking it easy for the first 5 till the car warms up and the oil pressure evens out @ 2kg/cm^2.. than at the end I tend to take it early coming back into my place..
also - what's oil pressure meant to sit on.. i'm guessing about 2kg/cm^2 normal cruising, than when I boost for a bit heads up toward 4kg/cm..
anyways - yeah take it easy for the last couple of minutes.. + get a minute or so while I open the garage door..
tt's are dangerous in my opinion...
what are you guys going to do if someone t-bones your car at high speed, and your sitting there trapped in your car unconscious....hey the ignitions been killed, but the cars still pumping fuel....
I personally dont want to be burnt in my car, so i chose not to use one...same goes if you roll the car and the fuel lines are cut/broken.....pumps fuel out still.....
Just dont drive on full boost for the last couple of minutes of your trip and you won't really need to let it idle down.
If you run an oil cooled only turbo such as a TO4 or something then letting it idle/cool down is more critical.
The standard turbo's and most other modern turbos are watercooled, so excess cool down is simply not required.
My turbo timer hits a maximum of 3:20 using full auto mode and that's travelling long distance sustaining 110km/h+. Usually it will run for around the 1:30mark after some spirited, some normal. Mine's integrated into my alarm so i can lock the car with it running and walk away. No dramas.
Thats why you hookup the handbrake sensor circuit.
That way if the handbrake isnt engaged and you turn the car off, the turbo timer doesnt operate.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
