Hi SK,
Just back from Angola and have measured the springs as you suggested.
Front
top 118 od
bot 113 od
spring 14
coils 7 total
2 progressive coils
rear
top 113 od
bot 100 od
spring 13.5
coils 8 total
2 progressive coils.
Ps also found the front sway bar is broken not sure how long that has been like that and i guess would not be helping with the loose rear during mid corner.
King Regards
Edited by tacker
  • Replies 378
Hi SK,
Front
top 118 od
bot 113 od
spring 14
coils 7 total
2 progressive coils
rear
top 113 od
bot 100 od
spring 13.5
coils 8 total
King Regards
Front is ~400 lbs per inch (7.1 kg /mm)
Rear is ~370 lbs per inch (6.6 kg/mm)
Yep, a broken front bar is not good for rear end stability.
:) cheers :laugh:
Cheers SK,
If your ever in this part of the world you have a night of free beers.
I am thinking that i still might need some softer springs in the rear, what would your recommend?
Regards
Hi SK,
I have some measurements here, hope you can help me out to figure the spring rates.
I.D: 90/79
O.D: 12
# : 6.650
Thanks SK :(
Sorry for the delay
270 lbs per inch (4.8 kg/mm)
:P Cheers :(
Hey sydneykid im getting new coilovers for my cefiro soon but would like to know what rates i have at the moment, these are the coilovers that it arrived in oz with, measurements are
front
coil OD - 85mm top and bottom
wire OD - 12mm
No of coils - 7.9
rear
wire OD - 11mm
No of coils - 7.25
measurements taken on the car without verniers so may be a bit rough, thanks heaps
Sory for the delay, I missed this one.
Front is ~ 500 lbs per inch (8.9 kg/mm)
Rear is ~ 415 lbs per inch (7.4 kg/mm)
:P cheers :(
Edited by Sydneykid
Couple to calculate please -
1. Coil ID = 98/66 mm
Wire OD = 11.75 mm
# of Coils = 7.25 turns
2. Coil ID = 96/71 mm
Wire OD = 12 mm
# of Coils = 7.75 turns
Thanks
1. 235 lbs per inch (4.3 kg/mm)
2. 225 lbs per inch (4.0 kg/mm)
:) cheers :
Hi Gary,
Got some measurements...
front:
WD: 13.8mm (???)
turns: 4.75
rear:
WD: 11mm
turns 7.25
cheers
Ben
Front = 160 lbs per inch (2.8 kg/mm)
Rear = 200 lbs per inch (3.6 kg/mm)
:) cheers :D
Hi gary,
I've got one for you.
Rears:
coil OD 91mm
wire OD 13mm
coils 9.4
length (lightly captive) 247mm
Fronts:
coil OD 90mm
wire OD 13mm
coils 7.75
length (lightly captive) 190mm
thanks very much Gary.
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to moth things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
    • Think ill be going hunting for bad earths and might just replace the alternator for shits n gigs as its an LS alternator but only about 5 years old with very minimal use in that 5 years.
