How Do I Tell What My Spring Rates Are?
  • Replies 378
Upper ID : 85mm
Lower ID : 80mm
Wire D : 12mm
# of coils : 10.5
Apexi Damper Adjustables for a 32.
Cheers
160 lbs/inch (3 kg/mm). I assume they are progressive wound? If so how many coils are wound close? With that info I can work out the high rate.
:) cheers :(
Hi SK,
Could you please work out my spring rates for these KG/MM springs that I had on my car before the Whitelines and Bilsteins. They have a strange shape so I have attached pics. I am after something a little stiffer than what I currently have...
FRONT
Coil ID = 67/97mm
Wire OD = 12 mm
# of Coils = 9.125 turns
Spring rate =
REAR
Coil ID = 87/101 mm
Wire OD = 13 mm
Spring rate =
Cheers
Hi SK,
FRONT
Coil ID = 67/97mm
Wire OD = 12 mm
Spring rate = 190 lbs/inch (3.4 kg/mm) on the soft rate and 550 lbs/inch (9.7 kg/mm) on the high rate
REAR
Coil ID = 87/101 mm
Wire OD = 13 mm
Spring rate = 180 lbs/inch (3.2 kg/mm) on the soft rate and 400 lbs/inch (7.2 kg/mm) on the high rate
Cheers
The progressive windings are close enough to ensure that they run 100% of the time on the high rate ie, the progression is only there to keep the springs trapped at full droop.
If you are looking for more roll control then stabiliser bars are the correct answer, not higher spring rates.
:huh: cheers :O
Hi SK,
Thanks for the info. Currently fitted I have the Whiteline springs, Bilstein shocks, Whiteline adjustable swaybars, adjustable castor rods, front/rear strut braces, front under arm brace, hicas removal bar, Whiteline pineapples and Whiteline rear camber kit fitted. The rear swaybar is set to the hardest setting and the front swaybar I have tried on soft and medium but it still doesnt feel quite right. The last alignment was pretty much to your specs, except I couldnt get enough front camber. Was looking at arms or bushes...
FRONT
Castor - +7 degrees
Camber - -1 degree
Toe - zero
REAR
Camber - -1.5 degrees
Toe - -2mm each side
I drive both on the road with street tyres and the track with Dunlop semi's. I want to be able to get around the corners on the track at high speed. Higher than what I am doing now anyway.
Would these harder KG/MM springs be OK with the valving on the group buy Bilsteins that I have or are they simply too stiff?? What are the spring rates of the Whiteline r33 springs I have in there now?? OIr what else do you recommend??
Thanks for your help.
:D cheers :D
Hi SK,
FRONT
Castor - +7 degrees
Camber - -1 degree
Toe - zero
REAR
This thread is really for spring rate calcs, so let's take this to PM.
:D cheers :D
  • 3 weeks later...
Hi Gary,
Please if you dont mind do some calc's on these and offer your opinion on the shocks.
King springs MDL - KDFL - 116
13mm dia
100mm id top
66 mm id btm
8.5 coils
Want to suit drag - wondering if stiff enough?
Hasemi M Sport Shocks- HPS 3201F - unable to find any specs on - single - double - any good??
Hey SK.
Could you check these out for me.
They are kings on a 31.
front
173mm OD
180mm OD
15mm wire
6 coils
Rear
113 mm OD
113mm OD
12mm wire
9 coils
The standard rear are same dia, but about 10.5mm or so wire and 11coils.
The height are good for the kings, but too hard in the rear and i've only basic monroe gas.
Fronts are GAB 4way adjustable as the front were a little soft, so went with a better dampening rate.
Reason i think they are too hard is they don't squat enough. (drag/daily street)
Thanks mate
SK, can you please calculate the rates for my progressive Apexi springs. Measurements taken with springs on car under load)
Front:
Thickness of wire: 13mm
Number of coils: 9.5 (approx 4 used up due to progressive rate - SEE PICS)
OD of coils: 10cm to 13cm (floor to roof direction)
Rear:
Thickness of wire: 14mm
Number of coils: 10.1 (approx 3 used up due to progressive rate - SEE PICS)
OD of coils: 13cm constant
My ride is a bit harsh, could be due to bump stops though (I have already trimmed the first groove off (~2cm). I'm using bilstein shocks front and rear.
Thanks very much :P
Edited by Greg
Hey SK,
Posting on behalf of a mate,
Lower OD = 90mm
Upper OD = 85mm
Wire OD = 12mm
11 coils
The top six coils are close together, there is almost no gap, see picture
http://www.nissansilvia.com/forums/index.p...howtopic=232464
whereas the bottom 5 are about 25mm apart - my mechanic says the bottom coils would provide travel but the top coils wouldn't. They are Black in colour and HKS
thanks
Brad
hey some bloke on ns.com wants to know the spring rate, these are his details:
I made the measurements with the spring still on the shock...
Lower OD: 90mm
Upper OD: 85mm
Wire OD: 12mm
# of coils: 11
The top 6 are close together, almost touching, whereas the bottom 5 are about 25mm apart (this is when the car is hoisted and the wheel is hanging - the spring isn't stressed)... my mechanic reckons I'd only get travel from the bottom coils which are spaced. They are black in colour and have a HKS logo.
Hey, Can u please calculate my spring rates?
Figures as follows..
FRONT
155mm inner diameter
14mm wire diameter
3.8-3.9 coils
REAR
125 outer diameter
10.75 coils
13mm wire diameter
5 Sacraficial coils
Thanks Steve
Hi Gary,
These are rear springs using "on the car "method
Lower OD 88mm Upper OD 88.75mm
Thickness 11.1mm
Turns 8.75
Regards
Simon
260 lbs /inch (4.6 kg/mm)
:) cheers :(
Hi Gary,
13mm dia
100mm id top
66 mm id btm
8.5 coils
270 lbs per inch (4.8 kg/mm). Bit too high a rate for drag racing, around 200 lbs/inch (3.6 kg/mm) is my usual choice. The standard springs would be better.
Hasemi........Nissan works driver from way back.......they used to use Bilsteins........but not a recognisable part number.
Doesn't matter any way, drag shocks need to be unique. Not much bump valving in the rear for rapid squat on launch. With lots of rebound valving to hold the squat. The front is the reverse, not much rebound valving for rapid droop on launch, with lots of bump valving to hold the nose up.
:) cheers :(
Hey SK.
front
173mm OD
180mm OD
15mm wire
6 coils
Rear
113 mm OD
113mm OD
12mm wire
9 coils
Thanks mate
Front = 165 lbs/inch (3kg/mm)
Rear = 82 lbs/inch (1.5kg/mm)
Note that R31's are not comparable with R32/33/34's, they have much different movement and leverage ratios. So the "effective" spring rates (at the tyres) are different. The springs rates are not too bad for road use, and are OK for drag use. So any problems that you are experiencing are more due to the poor shocks that you are currently using.
If you are serious about the drag racing, you need some properly valved shocks. Refer to the thread above.
This thread is for spring rate calculations, I have cleared my inbox a little, so if you want to carry on this discussion lets take it to PM's.
:) cheers :(
Front:
Soft rate is 200 lbs/inch (3.5 kg/mm)
High rate is 420 lbs/inch (7.5 kg/mm)
As you can see from the pictures, the "soft" rate is only used to take up space (keep the springs legally trapped at full droop). Hence it is running on the high rate almost all of the time.
Rear:
Soft rate is 170 lbs/inch (3 kg/mm)
High rate is 270 lbs/inch (4.8 kg/mm)
As with the front, the "soft" rate is only used to take up space (keep the springs legally trapped at full droop). Hence it is running on the high rate almost all of the time.
Thanks very much :)
Any wonder the ride is "a bit harsh".
:( cheers :)
Hey SK,
Lower OD = 90mm
Upper OD = 85mm
Wire OD = 12mm
11 coils
thanks
Brad
The soft rate is ~290lbs/inch
The high rate is ~ 870 lbs/inch (15.6 kg/mm) :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
:) cheers :(
