  • Replies 378
Coil OD = 60/60 mm
Wire OD = 10 mm
# of Coils = 7.5 turns
a lil ruff but best i cud do at the time
thanks :thumbsup:
60 mm OD = 40 mm ID, I have never seen a spring that small.
If you meant 60 mm ID, then;
Spring rate = 290 lbs/inch (5 kg/mm)
Cheers
Gary
yep my bad ment ID
looks like i need harder springs, still better then the stockies tho :laugh:
OK front rate for road tyres, a bit under done for R type tyres though.
Cheers
Gary
  • 3 weeks later...
Hey Gary looks like your the man for this sort of stuff
could you have a go at these coilovers??
Rear:
lower coil OD: 95
upper coil OD: 110
wOD: 13.5
no. of turns: 7
front:
lower coil OD: 100
upper coil OD: 120
wOD: 15
no. of turns: 6.25
cheers
Rear:
lower coil OD: 95
upper coil OD: 110
wOD: 13.5
no. of turns: 7
Spring rate = 350 lbs/inch (6 kg/mm)
front:
lower coil OD: 100
upper coil OD: 120
wOD: 15
no. of turns: 6.25
Spring rate = 500 lbs/inch (8.7 kg/mm)
cheers
OK spring rates for slicks, too high for everything else.
Cheers
Gary
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
# of Coils = 9.8 turns
Spring rate =
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
# of Coils = 9.4 turns
Spring rate =
I believe they're Nismo low springs, not sure though...
Cheers.
Edited by _Scotty_
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Spring rate = 120 lbs/inch (2 kg/mm)
From that low spring rate I assume that they are progressive. To get the actual (in use) spring rate you need to look at the coils, there should be some very closely wound together. They are sacrificial coils, they collapse onto each other as soon as the weight of the car is applied. Those coils need to be left out of the calculation.
Otherwise check the wire diameter.
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Spring rate = Spring rate = 170 lbs/inch (3 kg/mm)
These may be progressive as well.
Cheers.
Coil ID = 146mm
Wire OD = 12 mm
# of Coils = 5 turns
Spring rate = Spring rate = 95 lbs/inch (1.7 kg/mm)
Esplier springs apparently.
Is that a parrallel coil, ie; 146 mm all the way?
Cheers
Gary
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Correct, they are progressive, so how about:
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
# of Coils = 5.5 turns
Spring rate =
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
# of Coils = 7.4 turns
Spring rate =
Any idea if these are in fact Nismo springs?
Cheers Gary.
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Spring rate = 250 lbs/inch (4.4 kg/mm)
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Spring rate = 230 lbs/inch (4.1 kg/mm)
Cheers Gary.
They are fairly sensible rates, which Nimso do occasionally.
Cheers
Gary
Hey SK, springs in my old tanabe coilovers which I am thinking of putting back in measure like this:
Front:
Wire OD: 11.5mm
# Turns: 6.9 (2 sacrificial coils i think)
Rear:
Wire OD: 11mm
# Turns: 7.8 (2 sacrificial coils i think)
Some measurements seem odd but with digital callipers its difficult to get an repetitive reading, it seems that with the fronts they were thicker in the middle then the top and bottom but only by .5 mm so I just ignored it. Also the top and bottom of the coil are manipulated flat (2 sacrificial coils i think) so I don’t know if that affects anything but I would say most coilover springs are like that. They also have the little helper spring but as mentioned earlier that holds the main spring in and doesn’t affect the spring rate?
Do you know anything about the tanabe coilover shocks? They are height adjustable but not damper adjustable and are from the sus tec pro range (many years old).
Thanks in advance!
Edited by vespa
Front:
Wire OD: 11.5mm
490 lbs/inch (8.7kg/mm)
Rear:
Wire OD: 11mm
370 lbs/inch (6.7kg/mm)
Thanks in advance!
Spring rate is obviously way too high for road work, even too high for track work unless you are using slicks. The best (cost effective) recommendation I can give is to stick the rear springs in the front and buy a set of rear springs around 225/250 lbs/inch (4 to 4.5 kg/mm). Tanabe shocks are OK in a typical Japanese way, not good but OK. Try the spring swap and see how you like it.
Cheers
Gary
rear coil:
top 100
bottom 80
wire 10
turns 9
thanks
Are the top and bottom measurements the inside diameter? If so 80 lbs/inch (1.4kg/mm), which is very low.
Are they progressive coils? A number of coils that collapse onto one another as soon as the weight of the car is applied to them? Hence reducing the number of effective coils.
Usually around 4 coils, in which case the rate would be 180 lbs/inch (3.2 kg/mm)
Cheers
Gary
Can you knock these out for me, measurements may be off a touch as did them with shocks still on car & there was minimum room...
Note: springs are progressive, top 5 coils are wound tight, others are normal.
Fronts
Lower O.D. = 89.3mm
Upper O.D. = 89.3mm
Wire thickness = 12mm
No. Coils = 11.125
Rears
Lower O.D. = 85.6mm
Upper O.D. = 87mm
Wire thickness = 11mm
No. Coils = 11.125
thanks heaps!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
