How Do I Tell What My Spring Rates Are?
  • Replies 378
Posted Images
Coil OD = 60/60 mm
Wire OD = 10 mm
# of Coils = 7.5 turns
a lil ruff but best i cud do at the time
thanks :thumbsup:
60 mm OD = 40 mm ID, I have never seen a spring that small.
If you meant 60 mm ID, then;
Spring rate = 290 lbs/inch (5 kg/mm)
Cheers
Gary
yep my bad ment ID
looks like i need harder springs, still better then the stockies tho :laugh:
OK front rate for road tyres, a bit under done for R type tyres though.
Cheers
Gary
  • 3 weeks later...
Hey Gary looks like your the man for this sort of stuff
could you have a go at these coilovers??
Rear:
lower coil OD: 95
upper coil OD: 110
wOD: 13.5
no. of turns: 7
front:
lower coil OD: 100
upper coil OD: 120
wOD: 15
no. of turns: 6.25
cheers
Rear:
lower coil OD: 95
upper coil OD: 110
wOD: 13.5
no. of turns: 7
Spring rate = 350 lbs/inch (6 kg/mm)
front:
lower coil OD: 100
upper coil OD: 120
wOD: 15
no. of turns: 6.25
Spring rate = 500 lbs/inch (8.7 kg/mm)
cheers
OK spring rates for slicks, too high for everything else.
Cheers
Gary
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
# of Coils = 9.8 turns
Spring rate =
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
# of Coils = 9.4 turns
Spring rate =
I believe they're Nismo low springs, not sure though...
Cheers.
Edited by _Scotty_
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Spring rate = 120 lbs/inch (2 kg/mm)
From that low spring rate I assume that they are progressive. To get the actual (in use) spring rate you need to look at the coils, there should be some very closely wound together. They are sacrificial coils, they collapse onto each other as soon as the weight of the car is applied. Those coils need to be left out of the calculation.
Otherwise check the wire diameter.
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Spring rate = Spring rate = 170 lbs/inch (3 kg/mm)
These may be progressive as well.
Cheers.
Coil ID = 146mm
Wire OD = 12 mm
# of Coils = 5 turns
Spring rate = Spring rate = 95 lbs/inch (1.7 kg/mm)
Esplier springs apparently.
Is that a parrallel coil, ie; 146 mm all the way?
Cheers
Gary
Cheers
Gary
Yeah it is but they are definitely stiffer then standard. Maybe I wrote down the measurements wrong, Ill double check.
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Correct, they are progressive, so how about:
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
# of Coils = 5.5 turns
Spring rate =
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
# of Coils = 7.4 turns
Spring rate =
Any idea if these are in fact Nismo springs?
Cheers Gary.
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Spring rate = 250 lbs/inch (4.4 kg/mm)
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Spring rate = 230 lbs/inch (4.1 kg/mm)
Cheers Gary.
They are fairly sensible rates, which Nimso do occasionally.
Cheers
Gary
Hey SK, springs in my old tanabe coilovers which I am thinking of putting back in measure like this:
Front:
Wire OD: 11.5mm
# Turns: 6.9 (2 sacrificial coils i think)
Rear:
Wire OD: 11mm
# Turns: 7.8 (2 sacrificial coils i think)
Some measurements seem odd but with digital callipers its difficult to get an repetitive reading, it seems that with the fronts they were thicker in the middle then the top and bottom but only by .5 mm so I just ignored it. Also the top and bottom of the coil are manipulated flat (2 sacrificial coils i think) so I don’t know if that affects anything but I would say most coilover springs are like that. They also have the little helper spring but as mentioned earlier that holds the main spring in and doesn’t affect the spring rate?
Do you know anything about the tanabe coilover shocks? They are height adjustable but not damper adjustable and are from the sus tec pro range (many years old).
Thanks in advance!
Edited by vespa
Front:
Wire OD: 11.5mm
490 lbs/inch (8.7kg/mm)
Rear:
Wire OD: 11mm
370 lbs/inch (6.7kg/mm)
Thanks in advance!
Spring rate is obviously way too high for road work, even too high for track work unless you are using slicks. The best (cost effective) recommendation I can give is to stick the rear springs in the front and buy a set of rear springs around 225/250 lbs/inch (4 to 4.5 kg/mm). Tanabe shocks are OK in a typical Japanese way, not good but OK. Try the spring swap and see how you like it.
Cheers
Gary
rear coil:
top 100
bottom 80
wire 10
turns 9
thanks
Are the top and bottom measurements the inside diameter? If so 80 lbs/inch (1.4kg/mm), which is very low.
Are they progressive coils? A number of coils that collapse onto one another as soon as the weight of the car is applied to them? Hence reducing the number of effective coils.
Usually around 4 coils, in which case the rate would be 180 lbs/inch (3.2 kg/mm)
Cheers
Gary
Can you knock these out for me, measurements may be off a touch as did them with shocks still on car & there was minimum room...
Note: springs are progressive, top 5 coils are wound tight, others are normal.
Fronts
Lower O.D. = 89.3mm
Upper O.D. = 89.3mm
Wire thickness = 12mm
No. Coils = 11.125
Rears
Lower O.D. = 85.6mm
Upper O.D. = 87mm
Wire thickness = 11mm
No. Coils = 11.125
thanks heaps!
    • Oooohhh man did not bloody know that, that's amazing thanks heaps for sharing mate, bookmarked it!
    • In case you haven't come across it, there's also https://nissan.epc-data.com/ Go by VIN or drill down into your specific model and year and it'll have references for pretty much all the OEM parts. In very similar diagrams. Linked against amayama as well for ordering. Though they can be a bit slow and can be better to search around to get the parts locally.
    • Just in case anyone finds this in the future, here's a diagram sent to me by Nissan to identify these hoses. I ended up finding them through EFI Solutions though because Nissan reckons they need to order it from Japan, with a total cost of approx $110 inc. So it as cheaper with EFI anyway. https://www.efisolutions.com.au/blow-by-hose-rb25det-r33-wc34-c34-c35 https://www.efisolutions.com.au/blow-by-rocker-cover-hose-rb25-r33-wc34-c34-c35
    • This is an older post of mine but I just thought I should update it and explain what the problem was. Long story short the friction plates were below their service limit. New they are around 4mm, and service limit is (according to OSG) 3.5mm In addition the crank seal gasket wasn't sealing 100% anymore and that led to an oily clutch. Not sure what came first and why the clutch was worn after just 10,000km .. but all good now. OSG refresh kit via Nengun
    • My r34 GTT auto transmission is slowly letting go, slipping every now and again, tiptronic deciding to not keep it in 1st / 2nd when flooring it, taking longer to shift so I’m going going flush it and replace the filter and hope it lasts a bit longer.    I’ve got 10L of Penrite ATF FS at home and I’m going to use it for it unless ye completely recommend against it.  Penrite list it as compatible. i understand I should be using Castro Transzmax however it’s quite expensive and I already have 10L of the ATF fs. Has anyone here used atf fs for there got or heard of anyone? Or am I silly for even considering anything other then Castrol  Thanks for your advice
