  • Replies 378
Coil OD = 60/60 mm
Wire OD = 10 mm
# of Coils = 7.5 turns
a lil ruff but best i cud do at the time
thanks :thumbsup:
60 mm OD = 40 mm ID, I have never seen a spring that small.
If you meant 60 mm ID, then;
Spring rate = 290 lbs/inch (5 kg/mm)
Cheers
Gary
yep my bad ment ID
looks like i need harder springs, still better then the stockies tho :laugh:
OK front rate for road tyres, a bit under done for R type tyres though.
Cheers
Gary
  • 3 weeks later...
Hey Gary looks like your the man for this sort of stuff
could you have a go at these coilovers??
Rear:
lower coil OD: 95
upper coil OD: 110
wOD: 13.5
no. of turns: 7
front:
lower coil OD: 100
upper coil OD: 120
wOD: 15
no. of turns: 6.25
cheers
Rear:
lower coil OD: 95
upper coil OD: 110
wOD: 13.5
no. of turns: 7
Spring rate = 350 lbs/inch (6 kg/mm)
front:
lower coil OD: 100
upper coil OD: 120
wOD: 15
no. of turns: 6.25
Spring rate = 500 lbs/inch (8.7 kg/mm)
cheers
OK spring rates for slicks, too high for everything else.
Cheers
Gary
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
# of Coils = 9.8 turns
Spring rate =
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
# of Coils = 9.4 turns
Spring rate =
I believe they're Nismo low springs, not sure though...
Cheers.
Edited by _Scotty_
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Spring rate = 120 lbs/inch (2 kg/mm)
From that low spring rate I assume that they are progressive. To get the actual (in use) spring rate you need to look at the coils, there should be some very closely wound together. They are sacrificial coils, they collapse onto each other as soon as the weight of the car is applied. Those coils need to be left out of the calculation.
Otherwise check the wire diameter.
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Spring rate = Spring rate = 170 lbs/inch (3 kg/mm)
These may be progressive as well.
Cheers.
Coil ID = 146mm
Wire OD = 12 mm
# of Coils = 5 turns
Spring rate = Spring rate = 95 lbs/inch (1.7 kg/mm)
Esplier springs apparently.
Is that a parrallel coil, ie; 146 mm all the way?
Cheers
Gary
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Correct, they are progressive, so how about:
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
# of Coils = 5.5 turns
Spring rate =
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
# of Coils = 7.4 turns
Spring rate =
Any idea if these are in fact Nismo springs?
Cheers Gary.
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Spring rate = 250 lbs/inch (4.4 kg/mm)
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Spring rate = 230 lbs/inch (4.1 kg/mm)
Cheers Gary.
They are fairly sensible rates, which Nimso do occasionally.
Cheers
Gary
Hey SK, springs in my old tanabe coilovers which I am thinking of putting back in measure like this:
Front:
Wire OD: 11.5mm
# Turns: 6.9 (2 sacrificial coils i think)
Rear:
Wire OD: 11mm
# Turns: 7.8 (2 sacrificial coils i think)
Some measurements seem odd but with digital callipers its difficult to get an repetitive reading, it seems that with the fronts they were thicker in the middle then the top and bottom but only by .5 mm so I just ignored it. Also the top and bottom of the coil are manipulated flat (2 sacrificial coils i think) so I don’t know if that affects anything but I would say most coilover springs are like that. They also have the little helper spring but as mentioned earlier that holds the main spring in and doesn’t affect the spring rate?
Do you know anything about the tanabe coilover shocks? They are height adjustable but not damper adjustable and are from the sus tec pro range (many years old).
Thanks in advance!
Edited by vespa
Front:
Wire OD: 11.5mm
490 lbs/inch (8.7kg/mm)
Rear:
Wire OD: 11mm
370 lbs/inch (6.7kg/mm)
Thanks in advance!
Spring rate is obviously way too high for road work, even too high for track work unless you are using slicks. The best (cost effective) recommendation I can give is to stick the rear springs in the front and buy a set of rear springs around 225/250 lbs/inch (4 to 4.5 kg/mm). Tanabe shocks are OK in a typical Japanese way, not good but OK. Try the spring swap and see how you like it.
Cheers
Gary
rear coil:
top 100
bottom 80
wire 10
turns 9
thanks
Are the top and bottom measurements the inside diameter? If so 80 lbs/inch (1.4kg/mm), which is very low.
Are they progressive coils? A number of coils that collapse onto one another as soon as the weight of the car is applied to them? Hence reducing the number of effective coils.
Usually around 4 coils, in which case the rate would be 180 lbs/inch (3.2 kg/mm)
Cheers
Gary
Can you knock these out for me, measurements may be off a touch as did them with shocks still on car & there was minimum room...
Note: springs are progressive, top 5 coils are wound tight, others are normal.
Fronts
Lower O.D. = 89.3mm
Upper O.D. = 89.3mm
Wire thickness = 12mm
No. Coils = 11.125
Rears
Lower O.D. = 85.6mm
Upper O.D. = 87mm
Wire thickness = 11mm
No. Coils = 11.125
thanks heaps!
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
