Hi Gary,
Im trying to setup a nice highway cruising suspension setup from the myriad of parts i have collected.
This is a pic of some R34 GTR shocks with some unknown brand of spring that were on my 2nd set of bilsteins.
The front and rear springs measure the same ID/OD as the stock R34 springs, and are 13mm in diameter.
The fronts have 8.5 turns with 4 wound closely, 96mm ID
The rears have 7.5 turns with 3 would closely, 102mm ID
I hoping this will make a fair match. I'd rather not have to pay to have my 2nd set of bilsteins re-valved.
Cheers,
Ian
  • Replies 378
Ammendment to above... because i cant edit it!
Coil ID = 96/70 mm
Wire OD = 13 mm
# of Coils = 8.5 turns
The rears have 7.5 turns with 3 wound closely
Coil ID = 102/91 mm
Wire OD = 13 mm
# of Coils = 7.5 turns
Going through all the results i saw a request to know what standard R34 gtr spring rate measurements are. These measurements are from standard non vspec non NUR 2002 R34 GTR springs.
Front:
Coil ID = 97 mm top
Coil ID = 66.5mm Bottom
Wire D = 13 mm
# of Coils = 5 1/8 turns
Rear:
Coil ID = 102.5 mm top
Coil ID = 88.4 MM Bottom
Wire D = 13 mm
# of Coils = 4 1/8 turns
hey Sk, can you calculate my spring rate :P
front
Coil ID: 91mmTOP
91mm BOTTOM
Wire ID: 14mm
# of coils: 11.125
rear
Coil ID: 91mmTOP
91mm BOTTOM
Wire ID: 12mm
# of coils: 11.125
there were measured with a tape measure with the springs still on the shock.
Cheers
Edited by dori32
Coil OD = 125/100 mm
Wire OD = 14 mm
270 lbs/inch (4.8kg/mm)
Coil OD = 110/90 mm
Wire OD = 13 mm
# of Coils = 7.125 turns
300 lbs/inch (5.4kg/mm)
Coil OD = 125 mm
Wire OD = 15 mm
# of Coils = 9 turns
295 lbs/inch (5.3kg/mm)
Coil ID = 65 mm
Wire OD = 13 mm
# of Coils = 6.75 turns
690 lbs/inch (12.3kg/mm)
NB. 3 ODs and 1 ID
Can i please get them in KGmm and Lb"
Thanks Heaps
James
Sorry for the delay James, I have been tooo busy to forum.
Cheers
Gary
Hi Gary,
185 lbs/inch (3.3kg/mm)
480 lbs/inch (8.5kg/mm)
No true progression there, the progressive coils are too close together, so they would be at the 480 rate all the time when driving.
410 lbs/inch (7.3kg/mm)
No true progression there either, the progressive coils are too close together, so they would be at the 410 rate all the time when driving.
Cheers,
Ian
Typical Japanese R34GTR spring rates, too high in general plus they try and fix the understeer with out of proportion (to the weight) rear spring rates. A decent sized rear swaybar is much better fix for the understeer and it doesn't compromise the ride or traction anywhere near as much.
The sphositicated Bilstein valving (depending on part numbers) will typically handle a much softer spring rate without any problem.
Cheers
Gary
Coil ID = 96/70 mm
Wire OD = 13 mm
700 lbs/inch (12.5kg/mm)
Coil ID = 102/91 mm
Wire OD = 13 mm
215 lbs/inch (3.8kg/mm)
475 lbs/inch (8.4kg/mm)
Cheers
Gary
Front:
Coil ID = 97 mm top
Wire D = 13 mm
485 lbs/inch (8.7kg/mm)
Rear:
Wire D = 13 mm
390 lbs/inch (7.0kg/mm)
Cheers
Gary
front
Coil ID: 91mmTOP
91mm BOTTOM
Wire ID: 14mm
# of coils: 11.125
190 lbs/inch (3.4kg/mm)
Progressive?
rear
Coil ID: 91mmTOP
91mm BOTTOM
Wire ID: 12mm
# of coils: 11.125
110 lbs/inch (2.0kg/mm)
Progressive?
Cheers
Cheers
Gary
  • 4 weeks later...
hey Sk, can you please calculate my spring rate
front
Coil ID: 69mm top & bottom
Wire ID: 12.5mm
# of coils: 9.0 evenly spaced
rear
Coil ID: 71mm top & bottom
Wire ID: 11.5mm
# of coils: 9.125 evenly spaced
Thanks heaps
Hi SK
Can you help calculate my spring rates please. HKS coilovers for S13. Hypermax D. I'm guessing pretty stiff :bunny:
Not sure what to measure when it comes to the Coil OD's as I have progressive springs. So attached pic for your assistance.
Fronts:
Coil OD lowest coil 82mm/very top coil 82mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung.
Wire OD = 11mm
# of coils = 10.5
Spring Rate =
Rears:
Coil OD lowest coil 87mm/very top coil 87mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung
Wire OD = 11mm
# of coils = 10.125
Spring Rate =
Sam
  • 4 weeks later...
Hi SK could you please calculate some spring rates for me.
FRONT:
Coil ID = 99 top / 68 bottom (mm)
Wire OD = 12.7 mm
REAR:
Coil ID = 88.5 top / 77.5 bottom (mm)
Wire OD = 12 mm
# of Coils = 11 turns
thanks, Tim.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
