How Do I Tell What My Spring Rates Are?
  • 3 weeks later...
  • Replies 378
Posted Images
hi,
sorry if i am posting at the wrong place but i tried searching for the the correct topic but cant seem to find it (maybe using the wrong keywords).
i just bought a 1991 r32 gts, it has a set of D2 coilovers which are way too hard for my liking. The springs also seem short as i can't seem to wind it up to increase ride height.
my question is what are the best spring rates for normal street use and secondly; are there different heights for coilover springs?
Thanks in advance
Rizal
  • 1 month later...
hi Sydney kid
Do mind doing these for me.
l expext them to be pretty hard, my butt can vouch for it.
Front Coil ID: 70mm
Wire Dia: 12mm
# of Coils: 8.5
can you let me know kg/mm please mate...and i'll send you pics of the rear when i get them off the car,or any one eles can do it for me plssssss
cheers mate..
Edited by sun33
  • 1 month later...
Hi SK,
Can you please work out these spring rates?
Front:
Coil OD= 90mm top and bottom
Wire OD= 13mm
# of coils= 8.125 turns
Rear:
Wire OD= 13mm
# of coils= 9 turns
Thanks!
  • 4 weeks later...
I have an R34 GTT with Apexi coilovers, I don't know what the spring rates are but I know it is a bit too hard riding.
What i want to know is the best place, preferably in Eastern Melbourne suburbs, to have this looked at and hopefully get recommendations and possibly alternate springs made up.
  • 1 month later...
ID Both: 1.24100" (in) = 31.5214 MM
OD of Wire: .194" (in) = 4.9276 MM
# of coils: 31.3 turns
I would really appreciate it!!!!!!!!!!
THANKS!!!
Alex
Motorcycle spring, 25 lbs/inch
Cheers
Gary
Centeline
Cheers
Gary
Hi SK,
Front:
Wire OD= 13mm
230 lbs/inch (4.1 kg/mm)
Rear:
Wire OD= 13mm
# of coils= 9 turns
200 lbs/inch (3.6 kg/mm)
Thanks!
Cheers
Gary
hi Sydney kid
Front Coil ID: 70mm
Wire Dia: 12mm
# of Coils: 8.5
cheers mate..
315 lbs/inch (5.6 kg/mm)
Cheers
Gary
hi,
The standard ones, 165 lbs/inch (3kg/mm), Nissan didn't get it that wrong. If upgrading then nothing over 330 lbs /inch (6 kg/mm) in the front and 225 lbs/inch (4 kg/mm) in the rear.
If that gives too much roll for your liking then upgrade the swaybars, 27 mm front and 24 mm rear.
Yes, heaps, all you need to know is the ID, the rate and and the current free height. Then order accordingly.
Thanks in advance
Rizal
Cheers
Gary
these are off a set of Koni coilovers...
F
Coil ID = 64mm
Wire OD = 10 mm
# of Coils = 6.5 turns
300 lbs /inch (5.5 kg/mm)
R
Coil ID = 64mm
Wire OD = 10 mm
# of Coils = 7.1 turns
265 lbs /inch (4.7 kg/mm)
Thanks SK!
Nice rates
Cheers
Gary
Hi SK could you please calculate some spring rates for me.
FRONT:
Coil ID = 99 top / 68 bottom (mm)
Wire OD = 12.7 mm
# of Coils = 7.5 turns
275 lbs /inch (4.9 kg/mm)
REAR:
Coil ID = 88.5 top / 77.5 bottom (mm)
Wire OD = 12 mm
# of Coils = 11 turns
140 lbs /inch (2.5 kg/mm)
With 11 turns it's most likely a progressive spring, give me the coil spacing and I can work out the high rate as well (140 is the low rate).
thanks, Tim.
Cheers
Gary
Hey Gary can you please work your magic formula over these,
Rear
OD:- 92mm
Coils :- 8.2 turns
Springs Diameter :- 12.9mm
220 lbs /inch (3.9 kg/mm)
Front
OD :- 95mm
Coils :- 10.1 turns
Spring diameter :- 14.3mm
215 lbs /inch (3.8 kg/mm)
Thanks in advance
Cheers
Gary
Gary, one for you -
ID 80mm/80mm
Wire OD 16mm
8.5 turns
Thanks again J
620 lbs /inch (11.0 kg/mm)
Best you get friendly with your local chiropractor!
Cheers
Gary
Thanks in advance for the calculation SK,
My front one are
Coil ID = 70 mm
Wire OD = 13 mm
# of Coils = 9.5 turns
360 lbs /inch (6.4 kg/mm)
and the rear are
Coil ID = 59 mm
Wire OD = 12 mm
# of Coils = 12 turns
300 lbs /inch (5.4 kg/mm)
Cheers
Gary
Hi SK
Can you help calculate my spring rates please. HKS coilovers for S13. Hypermax D. I'm guessing pretty stiff :)
Not sure what to measure when it comes to the Coil OD's as I have progressive springs. So attached pic for your assistance.
Fronts:
Coil OD lowest coil 82mm/very top coil 82mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung.
Wire OD = 11mm
# of coils = 10.5
Spring Rate =
Low rate 115 lbs /inch (2.0 kg/mm)
High rate 285 lbs /inch (5.1 kg/mm)
Rears:
Coil OD lowest coil 87mm/very top coil 87mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung
Wire OD = 11mm
# of coils = 10.125
Spring Rate =
Low rate 100 lbs /inch (1.8 kg/mm)
High rate 260 lbs /inch (4.6 kg/mm)
Thanks :banana:
Sam
With those low low rates it would always be running around on the high spring rates, the extra coils are just there to soak up space (keep the coils trapped at full droop).
Cheers
Gary
    • Oooohhh man did not bloody know that, that's amazing thanks heaps for sharing mate, bookmarked it!
    • In case you haven't come across it, there's also https://nissan.epc-data.com/ Go by VIN or drill down into your specific model and year and it'll have references for pretty much all the OEM parts. In very similar diagrams. Linked against amayama as well for ordering. Though they can be a bit slow and can be better to search around to get the parts locally.
    • Just in case anyone finds this in the future, here's a diagram sent to me by Nissan to identify these hoses. I ended up finding them through EFI Solutions though because Nissan reckons they need to order it from Japan, with a total cost of approx $110 inc. So it as cheaper with EFI anyway. https://www.efisolutions.com.au/blow-by-hose-rb25det-r33-wc34-c34-c35 https://www.efisolutions.com.au/blow-by-rocker-cover-hose-rb25-r33-wc34-c34-c35
    • This is an older post of mine but I just thought I should update it and explain what the problem was. Long story short the friction plates were below their service limit. New they are around 4mm, and service limit is (according to OSG) 3.5mm In addition the crank seal gasket wasn't sealing 100% anymore and that led to an oily clutch. Not sure what came first and why the clutch was worn after just 10,000km .. but all good now. OSG refresh kit via Nengun
    • My r34 GTT auto transmission is slowly letting go, slipping every now and again, tiptronic deciding to not keep it in 1st / 2nd when flooring it, taking longer to shift so I’m going going flush it and replace the filter and hope it lasts a bit longer.    I’ve got 10L of Penrite ATF FS at home and I’m going to use it for it unless ye completely recommend against it.  Penrite list it as compatible. i understand I should be using Castro Transzmax however it’s quite expensive and I already have 10L of the ATF fs. Has anyone here used atf fs for there got or heard of anyone? Or am I silly for even considering anything other then Castrol  Thanks for your advice
