  • 3 weeks later...
  • Replies 378
hi,
sorry if i am posting at the wrong place but i tried searching for the the correct topic but cant seem to find it (maybe using the wrong keywords).
i just bought a 1991 r32 gts, it has a set of D2 coilovers which are way too hard for my liking. The springs also seem short as i can't seem to wind it up to increase ride height.
my question is what are the best spring rates for normal street use and secondly; are there different heights for coilover springs?
Thanks in advance
Rizal
  • 1 month later...
hi Sydney kid
Do mind doing these for me.
l expext them to be pretty hard, my butt can vouch for it.
Front Coil ID: 70mm
Wire Dia: 12mm
# of Coils: 8.5
can you let me know kg/mm please mate...and i'll send you pics of the rear when i get them off the car,or any one eles can do it for me plssssss
cheers mate..
Edited by sun33
  • 1 month later...
Hi SK,
Can you please work out these spring rates?
Front:
Coil OD= 90mm top and bottom
Wire OD= 13mm
# of coils= 8.125 turns
Rear:
Wire OD= 13mm
# of coils= 9 turns
Thanks!
  • 4 weeks later...
I have an R34 GTT with Apexi coilovers, I don't know what the spring rates are but I know it is a bit too hard riding.
What i want to know is the best place, preferably in Eastern Melbourne suburbs, to have this looked at and hopefully get recommendations and possibly alternate springs made up.
  • 1 month later...
ID Both: 1.24100" (in) = 31.5214 MM
OD of Wire: .194" (in) = 4.9276 MM
# of coils: 31.3 turns
I would really appreciate it!!!!!!!!!!
THANKS!!!
Alex
Motorcycle spring, 25 lbs/inch
Cheers
Gary
Centeline
Cheers
Gary
Hi SK,
Front:
Wire OD= 13mm
230 lbs/inch (4.1 kg/mm)
Rear:
Wire OD= 13mm
# of coils= 9 turns
200 lbs/inch (3.6 kg/mm)
Thanks!
Cheers
Gary
hi Sydney kid
Front Coil ID: 70mm
Wire Dia: 12mm
# of Coils: 8.5
cheers mate..
315 lbs/inch (5.6 kg/mm)
Cheers
Gary
hi,
The standard ones, 165 lbs/inch (3kg/mm), Nissan didn't get it that wrong. If upgrading then nothing over 330 lbs /inch (6 kg/mm) in the front and 225 lbs/inch (4 kg/mm) in the rear.
If that gives too much roll for your liking then upgrade the swaybars, 27 mm front and 24 mm rear.
Yes, heaps, all you need to know is the ID, the rate and and the current free height. Then order accordingly.
Thanks in advance
Rizal
Cheers
Gary
these are off a set of Koni coilovers...
F
Coil ID = 64mm
Wire OD = 10 mm
# of Coils = 6.5 turns
300 lbs /inch (5.5 kg/mm)
R
Coil ID = 64mm
Wire OD = 10 mm
# of Coils = 7.1 turns
265 lbs /inch (4.7 kg/mm)
Thanks SK!
Nice rates
Cheers
Gary
Hi SK could you please calculate some spring rates for me.
FRONT:
Coil ID = 99 top / 68 bottom (mm)
Wire OD = 12.7 mm
# of Coils = 7.5 turns
275 lbs /inch (4.9 kg/mm)
REAR:
Coil ID = 88.5 top / 77.5 bottom (mm)
Wire OD = 12 mm
# of Coils = 11 turns
140 lbs /inch (2.5 kg/mm)
With 11 turns it's most likely a progressive spring, give me the coil spacing and I can work out the high rate as well (140 is the low rate).
thanks, Tim.
Cheers
Gary
Hey Gary can you please work your magic formula over these,
Rear
OD:- 92mm
Coils :- 8.2 turns
Springs Diameter :- 12.9mm
220 lbs /inch (3.9 kg/mm)
Front
OD :- 95mm
Coils :- 10.1 turns
Spring diameter :- 14.3mm
215 lbs /inch (3.8 kg/mm)
Thanks in advance
Cheers
Gary
Thanks in advance for the calculation SK,
My front one are
Coil ID = 70 mm
Wire OD = 13 mm
# of Coils = 9.5 turns
360 lbs /inch (6.4 kg/mm)
and the rear are
Coil ID = 59 mm
Wire OD = 12 mm
# of Coils = 12 turns
300 lbs /inch (5.4 kg/mm)
Cheers
Gary
Hi SK
Can you help calculate my spring rates please. HKS coilovers for S13. Hypermax D. I'm guessing pretty stiff :)
Not sure what to measure when it comes to the Coil OD's as I have progressive springs. So attached pic for your assistance.
Fronts:
Coil OD lowest coil 82mm/very top coil 82mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung.
Wire OD = 11mm
# of coils = 10.5
Spring Rate =
Low rate 115 lbs /inch (2.0 kg/mm)
High rate 285 lbs /inch (5.1 kg/mm)
Rears:
Coil OD lowest coil 87mm/very top coil 87mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung
Wire OD = 11mm
# of coils = 10.125
Spring Rate =
Low rate 100 lbs /inch (1.8 kg/mm)
High rate 260 lbs /inch (4.6 kg/mm)
Thanks :banana:
Sam
With those low low rates it would always be running around on the high spring rates, the extra coils are just there to soak up space (keep the coils trapped at full droop).
Cheers
Gary
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
