  • 3 weeks later...
  • Replies 378
hi,
sorry if i am posting at the wrong place but i tried searching for the the correct topic but cant seem to find it (maybe using the wrong keywords).
i just bought a 1991 r32 gts, it has a set of D2 coilovers which are way too hard for my liking. The springs also seem short as i can't seem to wind it up to increase ride height.
my question is what are the best spring rates for normal street use and secondly; are there different heights for coilover springs?
Thanks in advance
Rizal
  • 1 month later...
hi Sydney kid
Do mind doing these for me.
l expext them to be pretty hard, my butt can vouch for it.
Front Coil ID: 70mm
Wire Dia: 12mm
# of Coils: 8.5
can you let me know kg/mm please mate...and i'll send you pics of the rear when i get them off the car,or any one eles can do it for me plssssss
cheers mate..
Edited by sun33
  • 1 month later...
Hi SK,
Can you please work out these spring rates?
Front:
Coil OD= 90mm top and bottom
Wire OD= 13mm
# of coils= 8.125 turns
Rear:
Wire OD= 13mm
# of coils= 9 turns
Thanks!
  • 4 weeks later...
I have an R34 GTT with Apexi coilovers, I don't know what the spring rates are but I know it is a bit too hard riding.
What i want to know is the best place, preferably in Eastern Melbourne suburbs, to have this looked at and hopefully get recommendations and possibly alternate springs made up.
  • 1 month later...
ID Both: 1.24100" (in) = 31.5214 MM
OD of Wire: .194" (in) = 4.9276 MM
# of coils: 31.3 turns
I would really appreciate it!!!!!!!!!!
THANKS!!!
Alex
Motorcycle spring, 25 lbs/inch
Cheers
Gary
Centeline
Cheers
Gary
Hi SK,
Front:
Wire OD= 13mm
230 lbs/inch (4.1 kg/mm)
Rear:
Wire OD= 13mm
# of coils= 9 turns
200 lbs/inch (3.6 kg/mm)
Thanks!
Cheers
Gary
hi Sydney kid
Front Coil ID: 70mm
Wire Dia: 12mm
# of Coils: 8.5
cheers mate..
315 lbs/inch (5.6 kg/mm)
Cheers
Gary
hi,
The standard ones, 165 lbs/inch (3kg/mm), Nissan didn't get it that wrong. If upgrading then nothing over 330 lbs /inch (6 kg/mm) in the front and 225 lbs/inch (4 kg/mm) in the rear.
If that gives too much roll for your liking then upgrade the swaybars, 27 mm front and 24 mm rear.
Yes, heaps, all you need to know is the ID, the rate and and the current free height. Then order accordingly.
Thanks in advance
Rizal
Cheers
Gary
these are off a set of Koni coilovers...
F
Coil ID = 64mm
Wire OD = 10 mm
# of Coils = 6.5 turns
300 lbs /inch (5.5 kg/mm)
R
Coil ID = 64mm
Wire OD = 10 mm
# of Coils = 7.1 turns
265 lbs /inch (4.7 kg/mm)
Thanks SK!
Nice rates
Cheers
Gary
Hi SK could you please calculate some spring rates for me.
FRONT:
Coil ID = 99 top / 68 bottom (mm)
Wire OD = 12.7 mm
# of Coils = 7.5 turns
275 lbs /inch (4.9 kg/mm)
REAR:
Coil ID = 88.5 top / 77.5 bottom (mm)
Wire OD = 12 mm
# of Coils = 11 turns
140 lbs /inch (2.5 kg/mm)
With 11 turns it's most likely a progressive spring, give me the coil spacing and I can work out the high rate as well (140 is the low rate).
thanks, Tim.
Cheers
Gary
Hey Gary can you please work your magic formula over these,
Rear
OD:- 92mm
Coils :- 8.2 turns
Springs Diameter :- 12.9mm
220 lbs /inch (3.9 kg/mm)
Front
OD :- 95mm
Coils :- 10.1 turns
Spring diameter :- 14.3mm
215 lbs /inch (3.8 kg/mm)
Thanks in advance
Cheers
Gary
Thanks in advance for the calculation SK,
My front one are
Coil ID = 70 mm
Wire OD = 13 mm
# of Coils = 9.5 turns
360 lbs /inch (6.4 kg/mm)
and the rear are
Coil ID = 59 mm
Wire OD = 12 mm
# of Coils = 12 turns
300 lbs /inch (5.4 kg/mm)
Cheers
Gary
Hi SK
Can you help calculate my spring rates please. HKS coilovers for S13. Hypermax D. I'm guessing pretty stiff :)
Not sure what to measure when it comes to the Coil OD's as I have progressive springs. So attached pic for your assistance.
Fronts:
Coil OD lowest coil 82mm/very top coil 82mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung.
Wire OD = 11mm
# of coils = 10.5
Spring Rate =
Low rate 115 lbs /inch (2.0 kg/mm)
High rate 285 lbs /inch (5.1 kg/mm)
Rears:
Coil OD lowest coil 87mm/very top coil 87mm. Widest part of OD is the middle of the top 5 coils and that measures 95mm. 5 coils at top close sprung
Wire OD = 11mm
# of coils = 10.125
Spring Rate =
Low rate 100 lbs /inch (1.8 kg/mm)
High rate 260 lbs /inch (4.6 kg/mm)
Thanks :banana:
Sam
With those low low rates it would always be running around on the high spring rates, the extra coils are just there to soak up space (keep the coils trapped at full droop).
Cheers
Gary
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
