  • Replies 378
Sorry it has taken this long!
Results are:
2.85 kg/mm or ~ 160 lb/in
Bare in mind i have used an average of your upper and lower OD's. Although this isnt 100% accurate, it will be in the vacinity of the correct value.
From what I've read, these seem like stock rates. How does it ride and handle?
Don't want to be rude mate, but these are not stock rates... My mate drift GTST32 is about as hard as mine, thing rides like track spec springs and I believe it handles insane, but I haven't driven another to compare. It would be very uncomfy as a daily, you can not physically push the car down at a corner at all, not even bounce it?
Any Ideas? Thanks for taking the time mate.
Ben
Edited by TrikkBen
All good...Im simply using the values you gave me.
For comparison, the first 5-10 rates that are in this thread that Sydney Kid calculated I also calculated using my spreadsheet. All were pretty much on spot +/- 5% IIRC. Furthermore, I calc'd my own spring rates and they were pretty much spot on with what I was given from SK. So I dont believe there's a problem with the spreadsheet...
Ill take another look when I get home and re-calc everything. But when I did calculate them, I checked and re-checked the values as I was a tad surprised going off the pictures.
  • 1 month later...
  • 3 weeks later...
  • 5 months later...
hey R32Abuser. (or anyone in here) can you help calculate spring rates for me?
front:
Coil ID = 14.7cm
Wire OD = 1.8cm
# of Coils = 5
rear:
Coil ID = 7.6cm/6.4cm
Wire OD = 1.4cm
# of Coils = 7
Appreciate the help.
Cheers!
  • 4 months later...
Hi SydneyKid or anyone else, could you please help calculate the (rear only) spring rates of my older model Cusco adjustable coilovers. They are really hard and I want to change springs.
Spring outer dia : about 90mm
Spring coil dia: 15mm
No. of coils: about 7.8? (the bottom of the last coil is sort of a 'split half diameter coil' - see pic)
Please disregard the lower 'helper springs'.
Thanks Ron
Thanks Ron
  On 09/03/2013 at 11:42 AM, rondofj said:
Oops sorry forgot the pic, here it is..
Hey mate i have the same ones im quite sure, They are Cusco Zero 2R - I was told the spring rates are 16/18 wayyyy to high
Thanks mate its not Zero2R, theres no damper adjustment, could be a Zero1, its baaaaad, 18/16 sounds plain horrible when Im told even 8/6 is bad! Oh boy here I was wanting to put softer 6/5 or 6/4 springs in.. Would my dampers get rooted with this low a rate?
Ok so got verniers today for extra accuracy.
Spring wire dia is 12.5mm
Spring outer dia is 89-90mm
No of 'active' coils is 6
Spring rate from a couple of US sites is 9kg/mm and thats for the rear- f**king hard hehe
Hi Gary and others,
I have an S13 silvia with RB25DET conversion. It came with Racing Logic coilovers installed, can you please help me work out spring rate?
This is from the rear:
Coil OD = 84mm
Wire OD = 11mm
# of coils = 6.9
It was sitting very low and was terrible for street, (physical pain on large pothole at 60km/h)! I have adjusted the height up and it is a little better, but still pretty rough on the street.
It still has all rubber bushes too not sure if this makes a difference.
Thanks for your help.
  • 11 months later...
  • 5 years later...
  • 2 months later...
man oh man...old old thread. BUT I have to ask...I have a couple springs I need help identifying.
14" spring front
Coil ID =  65mm
Coil OD= 85mm
Wire OD = 9.7mm
# of Coils =  10?turns
12" spring front
Coil ID =  65mm
Wire OD =  9.5mm
# of Coils =  7.75/turns
10" spring rear
Coil ID = 65.5 mm
Wire OD =  9.5mm
# of Coils =  5turns
I hope that the OP is still doing this!!! I need to figure out these springs and if they wont work for my application I need to order new. Please help!
Thanks in advance!!!
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
