Can you knock these out for me, measurements may be off a touch as did them with shocks still on car & there was minimum room...
Note: springs are progressive, top 5 coils are wound tight, others are normal.
Fronts
Lower O.D. = 89.3mm
Upper O.D. = 89.3mm
Wire thickness = 12mm
No. Coils = 11.125
270 lbs/inch (4.8kg/mm)
Rears
Lower O.D. = 85.6mm
Upper O.D. = 87mm
Wire thickness = 11mm
No. Coils = 11.125
210 lbs/inch (3.7kg/mm)
thanks heaps!
Cheers
Gary
  • Replies 378
Cheers
Gary
wow, ok I think I've stuffed up a measurement then because mine are rock hard & those spring rates are close to stock (z32).
Im assuming the springs are progressive as the top coils are wound a lot closer than the rest but perhaps Im wrong, any suggestions where I've messed up?
Coilovers are HKS Hipermax's & from what I can tell the lowest rates available (across whole range for z32) where fr=7, rr=6.
cheers, tim
cheers, tim
Can you post a picture Tim? That may show me what the progression is.
Otherwise you will have to measure the gaps between the coils. They should measure something like this,
3 mm / 5 mm / 5 mm / 5 mm / 15 mm / 20 mm / 20 mm / 20 mm / 20 mm /15 mm / 3 mm
Cheers
Gary
Cheers
Gary
yeah no problem, will double check measurements & snap some photos over the weekend.
thanks again.
this is rough but here it is for front springs hks hyper d's.
there are a few larger progressive rate coils nearer the top all wound in the one coil. there are 3 of them. Coil ID is 1)66mm 2)71mm 3)66mm
Coil ID = 61/61 mm
Wire OD = 12 mm
# of Coils = 10
could you work this out for me Gary.
Cheers!
Ok Gary heres a couple photos with spacing included on them.
Fronts:
Coil Dia. = 12mm
Top/Bottom O.D. = 89.5mm/89.5mm
No. of Coils = 11.125 (about half of the last coil is shaved so that spring sits flat)
Rears:
Coil Dia. = 11mm
Top/Bottom O.D. = 86.7mm/87.7mm
Have included Dia. of every coil on the rears as the change was more noticable, can get the fronts too if need be.
thanks for the help.
cheers, tim
Fronts:
Coil Dia. = 12mm
640 lbs/inch (11.5kg/mm)
Rears:
Coil Dia. = 11mm
475 lbs/inch (8.5kg/mm)
cheers, tim
Coil ID = 61/61 mm
Wire OD = 12 mm
# of Coils = 10
Cheers!
Assuming 7 active coils (3 progressive)
580 lbs/inch (10.3kg/mm)
Cheers
Gary
Front Coil
Upper OD = 113.95
Lower OD = 108.25
# of Coils = 9.25
Wire OD = 12.85
Rear Coil
Upper OD = 125.00
Lower OD = 112.25
# of Coils = 5.25
Wire OD = 13.7
Thanks. :-)
Front Coil
Upper OD = 113.95
Lower OD = 108.25
# of Coils = 9.25
Wire OD = 12.85
150 lbs/inch (2.7kg/mm)
I assume it's progressive wound, to get the correct effective rate you need to count the number of active coils, there will be around 4 to 5 coils that are inactive once the weight of the car is applied.
Rear Coil
Upper OD = 125.00
Lower OD = 112.25
# of Coils = 5.25
Wire OD = 13.7
350 lbs/inch (6.3kg/mm)
Thanks. :-)
Cheers
Gary
SYDNEY KID CAN YOU CONTACT ME !!! YOU`VE SENT ME THE WRONG SUSPENSION KIT. I HAVE R34 NOT R33. STOP IGONRING ME PLEASE.
Nobody is ignoring you. We get 40 to 50 PM's and emails a day, sometimes I have to actually do some work so I don't get to answer every PM and email every day. But I can assure you every single PM and every single email gets answered in the order in which we receive them. Sticking posts in innapropriate threads won't help you jump the que.
Cheers
Gary
top: 115mm
bottom: 75mm
# of coils: 9 and a bit
wire: 14mm
thanks
230 lbs/inch (4.1kg/mm)
If they are rears then they are most likely progressive, like this
http://www.skylinesaustralia.com/forums/up...61890_thumb.jpg
If yours are like that, then you need to tell me how many coils are close together, they are inactive coils. To work out the real spring rate I need to know the number of active coils.
Cheers
Gary
  • 3 weeks later...
Coil OD = 125/100 mm
Wire OD = 14 mm
# of Coils = 7.5 turns
Coil OD = 110/90 mm
Wire OD = 13 mm
# of Coils = 7.125 turns
Coil OD = 125 mm
Wire OD = 15 mm
# of Coils = 9 turns
Coil ID = 65 mm
Wire OD = 13 mm
# of Coils = 6.75 turns
NB. 3 ODs and 1 ID
Can i please get them in KGmm and Lb"
Thanks Heaps
James
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
