could be worse.... have you seen the sort of spring rates some of the japanese D1 drivers are using??
http://maxe.ausgamers.com/d1gp/imamura_.jpg
http://maxe.ausgamers.com/d1gp/maeda_.jpg
http://maxe.ausgamers.com/d1gp/suenaga_.jpg
18k / 16k.....    :blink:  :blink:
anyway,  back on topic.
won't different materials have different densities?  If you are using the formula I think you're using,  you need to use a modulus of rigidity, which is different for different materials.
All coil spring material (spring steel) is made to one of the 2 world wide standards, simplistically hot or cold winding. The end result (ie; the spring rate) is very similar once the finished product is normalised, tempered and or shot/peened. I have tested over a thousand coil springs in the course of business and the formula is very accurate. Most certainly accurate enough for this purpose.
As for the spring rates used in Japan, the Japanese have no real history of stabiliser bar upgrades. Not to the extent that we do with the KMac and Selbys history. Plus they seem to have no grasp of the art of shock absorber tuning like the Eurpopeans have. Add that to their bolt on mentality (good mechanics charge like brain surgeons) and it easy to understand why they rely excessively on spring rates to achieve what could be much better achieved usng other more sophisticated methods.
Since they all do it, they have no basis of comparison to realise that what they are doing is technically deficient. If drifting ever matures to the world stage they will quickly find that simplistically locking the suspension with rediculously high spring rates isn't a winning formula.
That said, they do a pretty god job with what they have. there is some skill that's for sure.
:O cheers :O
  • Replies 378
My rates don't really surprise me, although the balance does. I'd guessed 10/8 or 12/10 but 14/8 is a fairly different rates front to rear. Might have to double check my coil numbers before the wheels go back on.
Do you think this might be part of my traction problem? :D :D
You don't really expect to have TRACTION with those spring rates. The tyres will be leaping from each small bump to the next small bump. Because the spring rate is so hard, the tyres will have to flex themselves in an attempt to absord the impact energy. This dramatically deminishes their ability to follow the road surface. The chassis will recoil off the spring rates so much it will flex substantially as well. The shocks will have to have serious rebound damping to control the spring rate. Consequently as the chassis flexes, the shocks will tend to lift the wheels off the ground.
:D cheers :D
:D cheers :D
Cool, just asking.
Though, i might add, that a lot of suspension I have seen straight from japan, brands that spring to mind are Tien, hks, apexi n1 etc. tend to be the cheapo coilover of choice over there.
I think, partially, it depends on what you pay for. I've driven a car with 11k/9k spring rate - using proper race suspension, and compared to cheapo tien 8k/6k -- the ride was much more comfortable. So i think part of that was a better matched spring/shock - not to mention a better setup in general.
Anyway, I just purchased some european suspension for my skyline, so, we'll see how it goes. Quantum coilovers with 8k/8k springs
:D cheers :P
Thanks Gary, i spose that's why it was a drift car, not a drag car ;)
I would have thought that you would need SOME front traction :lol: :lol:
:D Cheers :)
garbage in garbage out is right.
you should only be concerned with the number of "free coils" in the loaded assembly. your results are skewed softer than the actual rate.
and your simplistic results are merely an average rate for the coil. no consideration given to variably wound coils.
I knwo the amount of free coil in a Skyline spring and allow for it.
I know the amount of free coil in a race coil and allow for it.
If you give me the spacing between the variable rate coils I can work out the various rates.
If you give me the taper on the wire I can work out the variable rate there as well.
Any time you want to check out the calculated rates for accuracy, just let me know, I have a spring rate tester.
:O cheers :D
Edited by Sydneykid
but you didn't ask for any of that extra info, so if someone had a variable rate coli, you and your calculations would have a bloody clue.
Then post up the numbers in this thread for Sydneykid to work out the spring rate like this;
Coil ID = 88/79 mm
Wire OD = 12 mm
# of Coils = 9.125 turns
my comments stand.
so you claim every spring made for skylines anywhere in the world will have the same amount of dead coil? and that somehow you magically know how many free coils each of these springs will have when installed just from that info you asked for? :lol: shit, you are good!
my comments stand.
The spring seats, top and bottom, determine the amount of dead coil.
I know the effect of the standard spring seats (for R32/33/34 models of Skylines).
Therefore I know the number of dead coils.
Race coils always have the same configuration, ground flat both ends, to keep the coils at 90 degrees to the seats.
Anyime you want to test it out, the offer stands.
:O cheers :D
my comments stand.
c'mon mate, give it a rest. no-one says you have to agree with everything gary says, but don't please just go seeking out all his posts to start an argument. I think some healthy disagreement is good, but this spring measuring thing is a tad petty don't you think?
you say petty, I say completely relevant. people should know that they are getting an approximated and average rate for their coil, based on a number of assumptions SK is making (and not telling them about) rather than the actual rate of the coil. (linear race coils excepted)
fair enough. i don't think people need them pinpointed down the the lb/inch though. I doubt i could tell the difference between a 300lb spring and a 305lb spring for instance. but that wasn't really my point, i was just saying everything doesn't have to be about you vs gary. perhaps it was just the way you made your point that made it seem to me like you are seeking out garys posts for a chance of an argument. if i'm wrong then i applogise, but sometimes the written word can be misinterpreted.
You should read back over my posts in this thread, #27 for a start.
There has only been one guy so far asking for progressive rate calculations which I did for him.
Because he was the only one, I haven't bothered to post up how to measure progressive rate springs so I can work out the rates.
If more people would like me to work out the rates of their progresive rate springs please let me know and I will post up the how to guide for the measurements.
If you don't like my calculations, perhaps you would like to take over this thread and do the calculations yourself for the guys. I have no problem with that, I have plenty of things to do.
:O cheers :D
Edited by Sydneykid
  • 2 months later...
Hello please help!
od: 14mm
turns: 8.4
I got these as in japan at the moment, this is the front spring, didnt get a brand
but now a little suspcious that the bottom of the shock was cut and a new mount welded on. the holes to bolt to the suspension are not exactly inline with the shaft by sight maybe 2-3mm out, thought this might put stress on the shaft and/or oil seals, what do you think? they look new and are suposed to be new accept the weld and bottom mount which looks doggy. Other thing is the rear is 10 times ajustable and the front is 16 !?
they were advertised as 10. Weird i think.
any coment apreciated.
Ps I think most people can apreciate there is always a factor of error but close enough dont you think, or is everyone a F1 driver?
SK would you mind doing my springs,
Front:
Coil OD = 145 mm top
Coil OD = 186 MM Bottom
Wire OD = 14 mm
# of Coils = 4.5 turns
Rear:
Coil OD = 145 mm
Wire OD = 15 mm
# of Coils = 6.125 turns
Thankyou for your help :cheers:
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
