SK would you mind doing my springs,
Front:
Coil OD = 145 mm top
Coil OD = 186 MM Bottom
Wire OD = 14 mm
# of Coils = 4.5 turns
Rear:
Coil OD = 145 mm
Wire OD = 15 mm
# of Coils = 6.125 turns
Thankyou for your help ;)
Sorry, for the dalay I missed seeing this post for a few days. I have replied to the PM, but for the other readers. The fronts are 185 lbs per inch and the rears 220 lbs per inch, which looks a little strange. Maybe check the dimension again just to be sure.
:huh: Cheers :)
  • Replies 378
Sydneykid
I don't have any so I can't get the measurements.  I was wondering in you know what the standard R34 GTR spring rates are?
Cheers...
Sorry, not an easy question to answer, there seems to be a few different standard spring rates in R34GTR's. I have seen three different rates, standard R34GTR, V Spec and N1 (maybe NUR spec), there may be others. The lightest was 165 lbs (3kg/m) per inch and the heaviest was 205 lbs per inch (3.7 kg/mm).
:P cheers :D
Coil OD = 86/82 mm
Wire OD = 11 mm
# of Coils = 11 ish turns?
i dunno if i got this right....my coils are strange in that the top coils (first 5 or so)are tighter together than the bottom and it goes from small to larger to small again...they are f***ken hard though....
Coil OD = 86/82 mm
Wire OD = 11 mm
Sorry for the delay in responding, I have been away from my enginering computer for a week. The first 2006 F3 round at Wakefield last weekend kept me busy.
That's a 2.5" progressive spring. The softest rate is ~225 lbs per inch and the highest rate (allowing for the 5 coils that are close together) is ~525 lbs per inch. Usually the soft rate is used only to ensure the spring is trapped at full droop. As soon as the weight of the car is applied, the close together coils sit on top of on another and you end up with the high rate all the time.
For a more accurate measurement you will have to remove the spring and measure the gaps between the coils. I then work out exactly the variable rates as the spring loads up.
:no: cheers :D
Edited by Sydneykid
Here is a test for your program. These are from my coilovers thank you.
Please sir.
Coil ID: 62.25mm
Wire Dia: 11.00mm
# of Coils: 7.75
AND
Coil ID: 62.00mm
Wire Dia: 10.10mm
# of Coils: 7.75
Cheers,
Dennis
Please sir.
Front Coil ID: 62.25mm
Wire Dia: 11.00mm
# of Coils: 7.75
AND
Rear Coil ID: 62.00mm
Wire Dia: 10.10mm
# of Coils: 7.75
Cheers,
Dennis
Hi Dennis,
Front = 355.063 lbs per inch
Rear = 261.929 lbs per inch (if 10.1 mm)
most likey 10 mm = 252.758 lbs per inch
:P Cheers :(
  • 3 weeks later...
Hi mate,
What do u reckon of these?? Supposed to be tanabe springs.
front lower OD - approx 95mm
front upper OD - approx 115mm
front wire OD - 13mm
front no. coils - 9
rears are progressive.
rear lower OD - approx 95mm
rear lower OD - approx 105mm
rear wire OD - 13mm
rear no. coils - 10
cheers,
rol
Edited by rol
Hi mate,
front no. coils - 9
rear wire OD - 13mm
rear no. coils - 10
cheers,
rol
Hi Rol, fronts are ~190 lbs per inch (3.4 kg/mm) and the rears are ~195 lbs per inch (3.5 kg/mm) on the soft rate. Send me a picture of rear springs, side on, so I can count the progressive coils and I will work out the high rate.
:thumbsup: cheers ;)
Gidday Sydneykid,
The springs are sustec / super H. They are a progressive spring rated spring.
front lower ID - 66mm
front upper ID - 97mm
front wire OD - 12mm
front no. coils - 8
progressive coils - 2
rear lower ID - 87mm
rear lower ID - 104mm
rear wire OD - 13mm
rear no. coils - 9
progressive coils - 3
These are hooked up with Ohlin's dampers which need a service. Do you know of anyone in Sydney who can help out?
Thanks mate
Steve
Gidday Sydneykid,
front no. coils - 8
rear wire OD - 13mm
rear no. coils - 9
Thanks mate
Steve
Hi Steve;
Fronts are ~230/345 lbs per inch (4.1/6.1 kg/mm)
Rears are ~175/305 lbs per inch (3.1/5.4 kg/mm)
None one I know will touch Japanese Ohlins, even the Australian Ohlins agent doesn't have spares.
Cheers
Gary
Thanks for the feedback Gary.
I have a contact in Quennsland who has established ties with the Japanese Ohlin's supplier which includes servicing. I was simply trying to avoid sending the shocks interstate.
Based on your experience in motorsport and nissan skylines, firstly what would you consider the optimum spring rate for an R33 GTST that will primary used for track work( super sprints, hill climb, racing) based on a weight including fluids and driver of 1250/1300kg, rollcage and seam welded, additional strut bracing, semi slicks, 240-300 rwkw.
Secondly the optimum rate for a daily driven R33 GTST.
Thanks Gary
Thanks Gary
We have the shock rates, stabiliser bar sizes and alignment settings to accommodate around 350 lbs per inch in the front and around 225 lbs in the rear for circuit racing. For road use around 225 lbs per inch in the front and 180 lbs per inch in the rear. Plenty of guys use higher spring rates than us to make up for their deficiencies in shock damping, anti roll and alignment.
:bunny: cheers :D
I have a stock gts4 (4 door, if it makes a difference), and was wondering what the front / back spring rates are.
I'll measure it when I get home, but even thought I couldn't find the info, I wouldn't be surprised if someone knew off the top of their head.
I'll edit this post to include measurements tomorrow, if I don't get an answer.
thanks
EDIT: Thanks. Should have realised it would be a rims off job, so I was gonna do it tonight, or on the weekend.
~2.9 kg/mm... thanks
Edited by ebola
thanks
Around 165 lbs.
:) cheers :)
hi Sydney kid
Do mind doing these for me.
l expext them to be pretty hard, my butt can vouch for it. :ermm:
Front Coil ID: 88mm
Wire Dia: 13.00mm
# of Coils: 7.75
AND
Rear Coil ID: 86mm
Wire Dia: 12
# of Coils: 7.75
:yes:
hi Sydney kid
l expext them to be pretty hard, my butt can vouch for it. :O
Front Coil ID: 88mm
Wire Dia: 13.00mm
# of Coils: 7.75
AND
Rear Coil ID: 86mm
Wire Dia: 12
# of Coils: 7.75
No that bad, 280 lbs per inch (5kg/mm) front and 210 lbs per inch rear (3.7 kg/mm), must be the shocks giving the harsh ride.
:) Cheers :)
:D Cheers :)
Hi Sydney Kid
thanks for that.
l accidentally gave you the wrong number of coils on the rear. its actually 8 1/2 coils.
sorry mate :thumbsup:
I have coilover's and l have adjusted the damper every which way and its still really hard. can the coilovers be hard from manufacture regardless of how much you adjust the damper??
I really dont like the ride at the moment, are you still doing that grooup buy from whiteline?
I have a 96 R33 GTST, and would like a soft susepnsion set up.
I was about to call whiteline to have some new springs made.
What do you think is a good idea.
Hi Sydney Kid
thanks for that.
sorry mate ;)
Based on 8.5 coils the rear spring rate is 185 lbs per inch (3.3 kg/mm), which is quite acceptable road rate.
Many adjustable coil overs only adjust the rebound rate, that's the damping in shock extension. The spring compresses to absorb a bump and then returns to its normal height. Rebound damping controls that return.
What makes a shock harsh is the bump valving, that's the damping in shock compression. The spring compresses to absorb a bump and the shock bump valving adds to the spring rate.
So by adjusting your shocks you may only be changing the rebound damping, which has virtually no effect on the ride harshness. If your coil over kit has sperical bearings in the stut tops that will also contribute to the harshness, especially if the shocks have big bump valving.
You could go for the Group Buy
http://www.skylinesaustralia.com/forums/in...showtopic=85467
As an alternative, since your spring rates are suitable, you could get Bilsteins shocks (as per the Group Buy)and 4 coil over kits. That way you can use your current springs and top seats plus have height adjustment. The coil over kits are around the same price as the Whiteline springs in the Group Buy, so it's a zero additional cost option.
I did similar for Dave last week, his comments follow
http://www.skylinesaustralia.com/forums/in...howtopic=114718
PM me if you want to discuss further.
:P cheers :thumbsup:
Edited by Sydneykid
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
    • Luckily for safety applications, with dedicated links not being used for any other traffic, you simply run ProfiSafe (or an equivalent safety comms protocol from other vendors) over the top of ProfiNet (if that's what you're using, or Ethernet IP if you're stuck in the world of American PLCs and not verking vis ze Chermans) and the redundancy is more about being able to know that you need to cause a system diagnostic lockout because you've lost one of your comms channels, rather than not knowing that you've lost your only comms channel. Granted, heartbeats and all that are possible and useable and all that, but some safety applications are are so time critical that you might not be able to afford a few milliseconds until the next check.
