Ohh finally I have experienced 33 stock turbo shitness.
On a cruise today, grabbed for 3rd gear and bannnnnnnnnng.
turbo sounds like a jet, really bad. I think the bearings ****ed up big time, at least it didnt spit out the exhaust wheel!
Ohh well - anyone got any suggestions or have a upgrade for sale! Im looking for low mount, stock manifold internal gated replacement.
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/
I have it set on 10, but usually, its gets a initial spike to 13 psi and drops, It somehow responds very quickly.
Its either now GT2530 or 2540 turbo.
Anyone got one for sale or know of one for or coming up for sale, please let me know.
Regards
Kim
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1444696
Regards
Kim
Id go the gcg highflow with a vg30 exhaust housing for sure. If I were going something from HKS a GTRS or a 2535
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1448031
Money talks. If you have the extra cash to buy HKS, you will end up with a better quality built turbo, a turbo that has been engineered to acheive the power@ higher boost, and better reliability. Also the turbines in a hi-flow turbo can be too big for the housings, which can cause other issues, such as fluttering while making boost.
That's an interesting comment Al, why do you say that over a high flow?
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1450144
your talking about brand new parts which is machined by gcg and balanced
how could they sell you something that isnt balanced or not fitted properly?
if it was a second hand bits or catridge or somethinf yeah ok could be issues
but not with a new bearing kits etc in it, dont see how?
i dont see how hks can make a better turbo when garrett make them in the first place
do you mean the combos avaiable and r and d they put in? you can always get whatever hks in garrett format, just gotta look around and ask the right people
anyway i dont really know what im talking about my clutch is angry and im still on stock turbo so who knows :confused:
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1450275
anyway i dont really know what im talking about..........
no arguments there...........:wassup:
The argument of "HKS Vs Garret" was been discussed numerous times, so everyone is entitled to their opinion.
The term "Hybrid", by definition means; "thing composed of incongruous (mismatched) elements." Now how can you argue that the hybrid turbo can compare to a HKS turbo. The amount of $$$$$$$$'s, research and engineering will greatly out way any Hybrid.
As stated b4, I myself have bought a second hand GCG hybrid and am very happy with the power, but know that a HKS turbo is far more superior. The HKS may not make a mountain load more power, but is an overall better product.
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1450461
guys
I would go for a Nice HKS or Trust or Apexi turbo ,but the MAIN thing that worries me is E P A!!
If I was back in Perth now, itd be getting HKS T04Z treatment, 50mm external gate, Motec, big fuel system, injectors and possibly even forged internals.
If I do this here, I will be raped by police again, I learnt my lesson on modified cars here, and Im defeinetly not gonna be pulling off shit evry time I get a EPA, we modify our cars to enjoy them, not to be looking over ur shoulder every time for a cop or worrying about someone dobbing you into the EPA.
I want simple stock looking high flow, bit more power and a newer reliable turbo.
https://www.sau.com.au/forums/topic/79202-i-blew-my-turbo/#findComment-1451088
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
