Hey people,
Just a question, has anyone on the forum performed a HID headlight coversion?
The reason I ask is that we do a bit of night driving and the lights on the R32 can be better. We've replaced the bulbs and it's still not good enough. It's really a safety issue, so does anyone have any information on them, are they worth doing?
I've seen a couple of kits in magazines for about $1100.
Can anyone help?
Thanks
Dan
https://www.sau.com.au/forums/topic/7921-hid-headlight-conversion/
I have an HID kit in my car...
One of the best modifications I have done to the car... Improved night vision 100-fold... I bought a generic H1 kit, and had to do quite a lot of modification so I could install it in such a way that I could remove the system and return it to stock. The kit wanted me to drill out the black cover on the back of the headlights, and I didn't want to do that... Even so, it only took about 2 hours for me to fabrictate mounting plates and install the entire HID kit.
Just make sure you aim it down so you don't blind oncoming traffic. :D
Originally posted by NO_RSPECT
hey Merli,
got an idea on the costing.
I bought my kit for $700... an "Eagle Eye" kit, made in Korea, and is cheaper than all the Philips/Cibie/etc kits...
Works perfectly though :uh-huh:
is HID the same as Xenon??
Yes. Xenon is the gas that is emmitted. HID stands for High Intensity Discharge which is the same thing. HID kits from the big names usually cost shitloads (upwards of $1500/$2K) but you can get generic ones for around $700 and more like Merlis. I've seen Merlis and they are very good. If you've seen S2000 headlights i reckon they're similar but more wide....
So definately worth doing?
Mine are standard on my car but if I got a car without them I'd do them :P
EDIT: How much brighter are they compared to the standard bulbs?
SHITLOADS! If a car is driving in front of me with normal lights mine totally overpower his so you cant even see his beam. Although the downside is that everyone flashes you cos they think you have high beam on and your friends won't drive in front of you anymore.
Originally posted by [ryan]
Merli - Which 33? Silver or White one?? Pics of the lights with the conversion??
I put them on the white one... I'll take pics for you guys...
Originally posted by franks
look at yang's R headlights here in this pic. tell me they aren't pointing UP!
if you can't see the pic, goto http://www.pbase.com/image/9278729
yeah, looks like it needs and adjustment.
Anyone with the workshop manual should have how to adjust it.
Basically you park the car x distance from a wall and adjust the brightest spots of the lights to be x distance from the ground up.
Or park a stock car next to the one needing adjustment and adjust so it's same as stock :P
They aren't pointing up, you can see that the projector is pointing straight ahead, the angle on the edge of the metal surround on the outside of the projector makes it look like it's pointing up :uh-huh:
i can't see what you're getting at? the whole inside of that headlight assembly is pointing upwards to me?
compare it to the GTSt in the foreground which is pointing straight ahead...
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
