Cosmetic Surgery Complete
Al
 Share
  • Replies 55
Posted Images
Thanks Al, cant wait to see this thing in the flesh!!
I asked for the rims, as im thinking of buying a set of them bu i thought my rears had to be 8.5 as the set im buying are from an S15
Would prefer not to mention price publically, as i was looked after (mate's friend) and still under quoted, as it must of been their first R33 they painted :P.
If anyone is interested in a quote just call Marcus on 0421169969.
  • 6 months later...
:O
Didn't realize that the thread had been re-opened, as i didn't get my usual e-mail notifications.
Well thanks for all the +ve feedback, it is really appreciated. All up, i am extremely happy with the cosmetic results and also my mechanical upgrades too :D.
I fully understand and appreciate that we all have different tastes. What looks awesome to me may not suit someone else and vis-versa, but at the end of the day only the owner needs to be satisfied with his/her work ;) .
I have decided to continue work on my "SKYLINE" backlight project. Should be ready and installed by this weekend.
Here are a few progress pics, with a progress report :).
After the spare "SKYLINE" facia was colour matched, i first used my Dremal tool to cut out the rear of the facia. In hin-sight it may have been better to complete the unit first, before painting, but time was an issue.
Then i used a sharp blade, off a Stanly knife, to gently cut off the paint from each letter. (Not as hard/long as i thought it would be :)).
Using a Jaycar "bread board" and my electronic experience, i positioned two hi-intensity LEDs in between each letter. This was done to try and minimize the focus of the LEDs. YES, it is damn bright :D; i may disconnect one wire and only use one LED between each letter.
It is now ready to be secured into position, then i will coat it with sicaflex to ensure it is as water resistant as the original.
Only one question left...
Do i hook it up to my parkers, so when i turn the h/lights on it will remain on, or do i hook it to my brake lights, so it turns off and on with my brake? :D:P
Where is a good place to look for colours and codes?
I used various paint sample books, Troy (ylwgtr2) was a GREAT help. Also kept a look out, on the road, at all red/burgundy cars that i passed. And asked friends for advise, thanks Pete :P.
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
