1 Apexi Turbo - AX53B70 incl. Apexi connecting pipe, 2x gaskets, water lines,
oil adapters $2,200.00
2 R33 Std Airbox and snorkel $100.00
3 16" Rims Std 300ZX - 5 number in total $450.00
4 HKS F-Con-V Engine Mgmt Computer $650.00
5 R33 Std Engine Mgmt Computer $350.00
6 HKS Intercooler and piping SOLD
7 Modified inlet manafold SOLD
8 Massive intercooler supplied by Subzero SOLD
9 3" Jasma (Japanese) Cat back exhaust - straight off R33 SOLD
10 3" Stainless steel dump pipe $220
11 Axas shift indicator light (Just plug into the car cigarette lighter socket and
the unit is ready to run No wiring) $120.00 Refer to http://www.autospeed.com/cgi-bin/browse.cg...duct=1003972002
12 R32 Crossover pipe $85.00
ONO. All prices exclude postage
call Dave 0414-232497 or email [email protected] (AH) or post (AH)
Have more photos on request
What type of power will the HKS intercooler flow?? is it better than a GTR Cooler?? Will it fit a series 1 GTST?? Im very interested.
Hi Darren,
HKS intercooler is 260mm x 400 x 65mm plus end tanks
Subzero intercooler is 300mm x 590mm x 95 plus end tanks
Not sure about flow comparisons
Definitely will fit Series 1 R33
Cheers
Dave
Note price includes piping and silicon hose and clamps!!!!
I was quoted $600 to replace the pipework on my existing car.
Thanks, I would assume it would probably flow better than a GTR item although not as big, did you use it? Was there a noticeable performance increase??
Much much better than the standard intercooler
Being manufactured by HKS the quality of the end tanks and cooler would br very efficent flowing
Quote:
Originally Posted by Mr_G
Hey champ,
Just saw you had a inlet manifold (modified) for sale...
Just curious, what throttle body does it use???
Was their any efficiency or power gain?
Thanks
Jason
P.S Is their any leaks???
Hi Jason,
Manafold uses the std throttle body.
When this setup was on I the car was dyno'd at 236kw at the wheels, when changed to std manafold and piping best I got was 217rwkw. Changed due to change in mechanics ????
No leaks....has been ported for better flow.
Cheers,
Dave
Hey champ,
Thanks
Jason
Hi Jason,
Cheers,
Dave
PM Sent regarding inlet manifold :)
will the dump pipe suit r33 s2??
also, u got any pics
Yes it came off a Series 2 R33.
Have to get it off the mechanic...hopefully tomorrow will have pics
Cheers Dave
