1 Apexi Turbo - AX53B70 incl. Apexi connecting pipe, 2x gaskets, water lines,
oil adapters $2,200.00
2 R33 Std Airbox and snorkel $100.00
3 16" Rims Std 300ZX - 5 number in total $450.00
4 HKS F-Con-V Engine Mgmt Computer $650.00
5 R33 Std Engine Mgmt Computer $350.00
6 HKS Intercooler and piping SOLD
7 Modified inlet manafold SOLD
8 Massive intercooler supplied by Subzero SOLD
9 3" Jasma (Japanese) Cat back exhaust - straight off R33 SOLD
10 3" Stainless steel dump pipe $220
11 Axas shift indicator light (Just plug into the car cigarette lighter socket and
the unit is ready to run No wiring) $120.00 Refer to http://www.autospeed.com/cgi-bin/browse.cg...duct=1003972002
12 R32 Crossover pipe $85.00
ONO. All prices exclude postage
call Dave 0414-232497 or email [email protected] (AH) or post (AH)
Have more photos on request
What type of power will the HKS intercooler flow?? is it better than a GTR Cooler?? Will it fit a series 1 GTST?? Im very interested.
Hi Darren,
HKS intercooler is 260mm x 400 x 65mm plus end tanks
Subzero intercooler is 300mm x 590mm x 95 plus end tanks
Not sure about flow comparisons
Definitely will fit Series 1 R33
Cheers
Dave
Note price includes piping and silicon hose and clamps!!!!
I was quoted $600 to replace the pipework on my existing car.
Thanks, I would assume it would probably flow better than a GTR item although not as big, did you use it? Was there a noticeable performance increase??
Much much better than the standard intercooler
Being manufactured by HKS the quality of the end tanks and cooler would br very efficent flowing
Quote:
Originally Posted by Mr_G
Hey champ,
Just saw you had a inlet manifold (modified) for sale...
Just curious, what throttle body does it use???
Was their any efficiency or power gain?
Thanks
Jason
P.S Is their any leaks???
Hi Jason,
Manafold uses the std throttle body.
When this setup was on I the car was dyno'd at 236kw at the wheels, when changed to std manafold and piping best I got was 217rwkw. Changed due to change in mechanics ????
No leaks....has been ported for better flow.
Cheers,
Dave
Hey champ,
Thanks
Jason
Hi Jason,
Cheers,
Dave
PM Sent regarding inlet manifold :)
will the dump pipe suit r33 s2??
also, u got any pics
Yes it came off a Series 2 R33.
Have to get it off the mechanic...hopefully tomorrow will have pics
Cheers Dave
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
