F/S or SWAP - GENUINE NISMO 300klm CLUSTER with 67***klms on it
For Sale as above
- Genuine NISMO
- VERY LOW KLMS only 67***klms
Perfect on condition
asking $350 or Swap for
- 600x300x70mm Front-Mounted Intercooler
OR
- FMIC Intercooler Piping
or whole Front-mounted Intercooling kit with cash adjustment...
PICTURES OF CLUSTER
Call me on 0401299729 or 0424678535
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
