... and then there were 8.
Jamezilla
 Share
For those of you who don't know, one of the 12 Apostles collapsed over the weekend, leaving only 8 of the limestone rock formations left.
http://www.news.com.au/story/0,10117,15815...0-28102,00.html
If you have not yet driven to Port Campbell to see these, then I suggest you make it a priority for a spare weekend, before there are none left. Since I first saw them on a school excursion almost 20 years ago - the London Bridge formation has collapsed also.
The drive along the Great Ocean Road is nothing short of spectacular - and makes a fabulous weekend away. The Golden Chain motel in Port Campbell even has spa rooms - perfect for a 'wink wink' weekend away :P
As a club, we try to have at least 2 drives down the Great Ocean Road every year - the first having been in March. We'll try to plan another one later in the year to take advantage of nicer weather, and hope that in the meantime, nature plays nicely and the rest of the Apostles stay there.
James
20 years ago, now you are showing your age! :uh-huh:
I have done the drive a couple of times and enjoyed it immensly. Maybe a remembrance cruise needs to be organised for the demise of the 9th Apostle.
Yeah for sure, I was spewing I missed the GOR cruise, looking for a reason to make the trek.
im thinking about going for a drive with my mate down the GOR on Sunday morning depending on weather and if i go out on saturday night
Let me know if you do, If I can't get a few mates to go on saturday I'll be interested in going on sunday.
ye no probs dude, my mate should be coming with his R1 and he never takes it out in the rain so ye just depends on the weather and if we go out the night before
any 1 else interested?
Could your arm be twisted to go if weather is good???
Arm is quite twistable, but the weather this weekend is looking quite crap. That being said, I'm sure every man & his dog will take the opportunity to head down this weekend.
I'll have a chat to a few mates and see when they're interesting in making the pilgrimage.
:cheers:
oh & i'll be sure to take the disinfectant :Pimp2:
:cheers:
Nice, Let me know.
jules 0403 24 24 78
 Share
    • You don't need an AC mechanic to fit it. You do need one to vac the system down and fill it. That's how you get refrigerant.
    • Well, it's actually probably worse than you think. I think you have to (minimally) install GKTech's spherical bush replacements to the lower arm's inner ends, because you absolutely cannot subject the original (or poly) bushes to that much misalignment. The better option being to replace the whole lower arm with GKTech's unit. This brings sphericals to the lower inners either way you do it. And are you aware that the kit is weld in and you have to take the subframe out of the car to get it fitted? It's a fair bit of work. These issues both drive my ongoing dithering about doing this to my car, for the last couple of years.
    • The website said you need a AC technican to swap it in. Is that true? How did you fill the refridgerant? Was it easy to install?  If i just got the bracket and the new smaller AC compressor, would the other components be compatible with R134?
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
