torrent help
Archie@
 Share
hi Guys,
I know this isn't really game related but since this is were most of the tech heads hang out I thought it might be more appropriate to post here than elsewhere..... anyways to the point.
I’ve been downloading a fair few torrents, but the problem is, it takes for ever. I have a cable connection so I would at least like a 200-300kbs download and not the pathetic 20-30kbs that I am getting.
I’ve read up a bit about opening ports etc etc but the problem is I’m using a USB modem... to be precise a Motorola surfboard hunka junk, so there is only one port.
is there anything I can do to up the speed of the downloading of por.... i mean family orientated movies or am I doomed forever in eternal frustration whilst the torrent hogs my precious counterstrike time.
ta
i get similar speed to you also, the most i got for one torrent was 70kbs. it all depends on the number of seeds and peers there are. also from what i under stand its an upload download ratio so if your upload speed is high so is your dl speed. sif..im with optus cable so im stuck with 128kbs upload hence thats the reason why my dl's suck ass.
USB modem should make very little difference dude, (B1) MR_fanny might be onto something RE upload speeds.
Im on DSLAM 12mb DSL and upload at about 300kbs that could be your prob. "upload speeds"
hehe yeah....i just found out what the problem was.... torrent shows upload/download in bits so the 15 odd bits i'm receiving is more like 125 kilobytes.
Now i just actually realised that my ISP capps my uploads at 125kbs were as my download speed isn't capped. so no matter what it seems im destined to have to set downloads for overnight jobs.
ohhh welllll.........
cheers guys
Cap uploads around 10-11Kb/s.
Bittornado is a decent reliable torrent client, I find it performs better than the popular Azureus.
Any more than ~10-11Kb/s and you will have trouble sending ack packets to your sender.
In lamens, the sender sends a packet and waits to hear back from the receiver, once it hears back it sends another.
You need to reserve some upload bandwidth for ack packets.
Also.. Don't go doing these 'rwin/mtu etc optimizations' you find around the web.
Often than not they only make matters worse.
WinXP does a fairly good job on its own.
The stuff you have read about port forwarding is on a router/firewall, since you don't have a router you just have a modem, you won't need to forward ports, but i hope you are running a firewall on your computer since you don't have a router - just open the ports that your bit torrent client uses on your firewall. Check the preferences of your bit torrent client to find out what ports to forward.
I'm on 1500/256 ADSL, and on good sourced torrents can max out my connection at 160kB/sec...
If your on cable, both Telstra and optus cap at 128kbit/s upload which is around 12-15kB/sec... set your bit torrent clients max upload to 10kB/sec.
Next is to find torrents which have good sources... Usually new torrents released have the best speeds, the more people on them usually the better speeds. Ratio sites like filelist.org and wild-bytes.org are ratio sites(they keep track of how much you download and upload) i always get good speeds on.
Lastly always try to make sure you share the torrent once you've finished downloading till you have uploaded as much as you downloaded (1:1 ratio).
slow down egg heads! :D
so what program are u using to d/l? im after a good one also, i was using one which i cant remember but i was rank, now i try and get most of my stuff off BearShare, get really fast speeds out of that most of the time, but it doesnt have as many things as a torrent program would.
Cheers
All the best.
The line about having your upload speed set high to increase download speeds is incorrect: quite often its the opposite. I cap most of my torrents at about 4-5Kbyte/sec upload and can quite happily do hundreds of kbytes down per sec.
Each torrent only needs a couple of Kbytes upstream so it can send enough data out to let the peers/seed/tracker know what's going on.
Lucien.
slow down egg heads! :)
Cheers
All the best.
currently using bittorrent.... reasonably good. i find the best thing about it is that you are not limited to using one site to download from. i usually search torrents when it's a slow day at work, e-mail the torrent file home and when i get home i can just start the download in bittorrent.
Azureus is a good popular one, only down side is it written in java, i hate java, so slow.
I use ABC (http://pingpong-abc.sourceforge.net/) which is ok, seems to work fine for me, but friends have had a couple of problems with it.
As for the upload thing, it depends how the client is written - But from what i understand the upload cap should be for uploading of data of the torrent itself, not the requests out to the tracker and connecting to peers etc... otherwise it would flood itself in with the data being uploaded. Also from the tracker specs i've read, which was a while ago - they do take note of how much you uploaded and are uploading, and give you more/less sources, so by uploading 10k/s rather than 5k/s, you should get better download speeds (as long as you aren't flooding/maxing out your upload bandwidth). But if your getting speeds your happy with by capping the upload at a lower rate then your doing fine :)
Yes, but it also means its sandboxed and crossplatform. I must say that despite it being written in Java, I haven't noticed it being unresponsive.
I use to use ABC but got frustrated with its general instability and slow pace of development.
Lucien.
If you've got good bandwidth sign up for a good news server & smash Usenet. I get 500-700k in the binary newsgroups. A good server will cost $USD 10-15 per month, but its leech heaven. Bittorrent/Fast Track et al ain't what it used to be, Usenet just gets better...
 Share
    • Right.  I'll try my best at a concise "bring you up to speed" on stuff that may be missing here - obviously open to questions or further input from others as relevant. Here's a datalog from a responsive turbo setup with electronic boost control being used a bit, to keep it simple I've marked 3 points of interest.  All of these charts are on the same time scale on the X-axis, so you can reference what engine rpm is doing in the top graph, boost and EMAP (exhaust backpressure) in the second graph, and turbo rpm in the bottom graph. A) The turbo gets it's power from exhaust gas, and pumping air takes work.  As a result you can't just spin a turbo with a fixed amount of exhaust energy and expect it to keep spooling - the bigger the turbo (ie, the more air it can push) the more exhaust energy you need to drive it.   The most obvious ways of getting more exhaust energy are by adding displacement, adding boost, or adding rpm - but as you add any of these the turbo also needs to do a bit more work so there is a big balance of these things needed to even get to your target boost and sometimes that's not even possible. What you can see in step "A" is that there isn't enough engine rpm or boost to reach the level we want, so this is where "lag" is.  The dyno run continues and rpm increases, which gives enough energy to increase boost, which helps spool  the turbine speed up even more - so you can see that the rate that the boost (and turbo speed) are starting to ramp up faster than the engine rpm is, so turbo is really starting to wake up as the graph gets closer to point B....   B) At this point we've been able to reach the boost that is actually desired at this point.   To stop the boost from going further than this the wastegate will open and bypass gas past the turbine, meaning it doesn't continue accelerating at the point it was before but instead carry on at a more progressive rate which matches what the engine needs.   The wastegate will have a spring in it which is rated to a specific pressure where it will start bypassing, but electronic boost control (managed by the ECU) can adjust how much pressure the spring sees in order to allow some tunability on how much boost the wastegate actually sees, and therefore how much exhaust it bypasses.   The tune in this case stops boost from ramping up HARD at around 21-22psi just before 4000rpm, then as the rpm continue it allows boost to continue up to around 25psi higher in the rpm.   You can see the turbo speed fairly steadily increases through the rpm to ensure it's keeping up with the increasing airflow demand due to the engine speed being higher and boost being pretty steady.   If the boost dropped off after a point then you may see the turbo speed level off or even drop.   C) You can see that despite the boost pressure staying pretty flat here, the exhaust pressure is steadily increasing and at this stage has overtaken boost pressure.   This isn't unusual, and is largely as a result of the increasing energy needed by the turbo to pump more and more air to suit the needs of the engine as it revs out further.   There are a bunch of variables in regards to how much back pressure there will be on a given turbo etc, but its one of the factors we manage when sizing and tuning a turbo setup.   When exhaust back pressure starts exceeding boost pressure you will eventually start seeing signs that the turbo is running out, the engine gets less keen to make more power and it gets harder to raise boost further. In this case it's a fairly acceptable compromise for the power level (around 630kw on a 3litre engine with full boost by 4000rpm), but you'd not want to push it a lot harder than this.  The maximum speed rated for the compressor wheel on this setup is around 125,000rpm so you can see its starting to get close on that side as well - I feel like this kind of illustrates some of the turbo related things we both decide on how far to push, and are also limited to how far we can push depending on the parts combination. Hope this helps more than it confuses things
    • For that influx of Spammers we had I made no pic posting and no PM's for first ten posts. This is group based and I've manually updated @Beanie to the Members group which will open up the images and PM's.
    • Thx for the reassuring reply. I’ve got above legal clearance  going in for roadworthy Friday… fingers crossed it’s keeping me awake  bloody nanny state
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
