hi Guys,
I know this isn't really game related but since this is were most of the tech heads hang out I thought it might be more appropriate to post here than elsewhere..... anyways to the point.
I’ve been downloading a fair few torrents, but the problem is, it takes for ever. I have a cable connection so I would at least like a 200-300kbs download and not the pathetic 20-30kbs that I am getting.
I’ve read up a bit about opening ports etc etc but the problem is I’m using a USB modem... to be precise a Motorola surfboard hunka junk, so there is only one port.
is there anything I can do to up the speed of the downloading of por.... i mean family orientated movies or am I doomed forever in eternal frustration whilst the torrent hogs my precious counterstrike time.
ta
https://www.sau.com.au/forums/topic/79343-torrent-help/
i get similar speed to you also, the most i got for one torrent was 70kbs. it all depends on the number of seeds and peers there are. also from what i under stand its an upload download ratio so if your upload speed is high so is your dl speed. sif..im with optus cable so im stuck with 128kbs upload hence thats the reason why my dl's suck ass.
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1446213
USB modem should make very little difference dude, (B1) MR_fanny might be onto something RE upload speeds.
Im on DSLAM 12mb DSL and upload at about 300kbs that could be your prob. "upload speeds"
hehe yeah....i just found out what the problem was.... torrent shows upload/download in bits so the 15 odd bits i'm receiving is more like 125 kilobytes.
Now i just actually realised that my ISP capps my uploads at 125kbs were as my download speed isn't capped. so no matter what it seems im destined to have to set downloads for overnight jobs.
ohhh welllll.........
cheers guys
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1447728
Cap uploads around 10-11Kb/s.
Bittornado is a decent reliable torrent client, I find it performs better than the popular Azureus.
Any more than ~10-11Kb/s and you will have trouble sending ack packets to your sender.
In lamens, the sender sends a packet and waits to hear back from the receiver, once it hears back it sends another.
You need to reserve some upload bandwidth for ack packets.
Also.. Don't go doing these 'rwin/mtu etc optimizations' you find around the web.
Often than not they only make matters worse.
WinXP does a fairly good job on its own.
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1447756
The stuff you have read about port forwarding is on a router/firewall, since you don't have a router you just have a modem, you won't need to forward ports, but i hope you are running a firewall on your computer since you don't have a router - just open the ports that your bit torrent client uses on your firewall. Check the preferences of your bit torrent client to find out what ports to forward.
I'm on 1500/256 ADSL, and on good sourced torrents can max out my connection at 160kB/sec...
If your on cable, both Telstra and optus cap at 128kbit/s upload which is around 12-15kB/sec... set your bit torrent clients max upload to 10kB/sec.
Next is to find torrents which have good sources... Usually new torrents released have the best speeds, the more people on them usually the better speeds. Ratio sites like filelist.org and wild-bytes.org are ratio sites(they keep track of how much you download and upload) i always get good speeds on.
Lastly always try to make sure you share the torrent once you've finished downloading till you have uploaded as much as you downloaded (1:1 ratio).
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1447799
slow down egg heads! :D
so what program are u using to d/l? im after a good one also, i was using one which i cant remember but i was rank, now i try and get most of my stuff off BearShare, get really fast speeds out of that most of the time, but it doesnt have as many things as a torrent program would.
Cheers
All the best.
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1448793
The line about having your upload speed set high to increase download speeds is incorrect: quite often its the opposite. I cap most of my torrents at about 4-5Kbyte/sec upload and can quite happily do hundreds of kbytes down per sec.
Each torrent only needs a couple of Kbytes upstream so it can send enough data out to let the peers/seed/tracker know what's going on.
Lucien.
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1448982
slow down egg heads! :)
Cheers
All the best.
currently using bittorrent.... reasonably good. i find the best thing about it is that you are not limited to using one site to download from. i usually search torrents when it's a slow day at work, e-mail the torrent file home and when i get home i can just start the download in bittorrent.
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1449356
Azureus is a good popular one, only down side is it written in java, i hate java, so slow.
I use ABC (http://pingpong-abc.sourceforge.net/) which is ok, seems to work fine for me, but friends have had a couple of problems with it.
As for the upload thing, it depends how the client is written - But from what i understand the upload cap should be for uploading of data of the torrent itself, not the requests out to the tracker and connecting to peers etc... otherwise it would flood itself in with the data being uploaded. Also from the tracker specs i've read, which was a while ago - they do take note of how much you uploaded and are uploading, and give you more/less sources, so by uploading 10k/s rather than 5k/s, you should get better download speeds (as long as you aren't flooding/maxing out your upload bandwidth). But if your getting speeds your happy with by capping the upload at a lower rate then your doing fine :)
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1449381
Yes, but it also means its sandboxed and crossplatform. I must say that despite it being written in Java, I haven't noticed it being unresponsive.
I use to use ABC but got frustrated with its general instability and slow pace of development.
Lucien.
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1449396
If you've got good bandwidth sign up for a good news server & smash Usenet. I get 500-700k in the binary newsgroups. A good server will cost $USD 10-15 per month, but its leech heaven. Bittorrent/Fast Track et al ain't what it used to be, Usenet just gets better...
https://www.sau.com.au/forums/topic/79343-torrent-help/#findComment-1451053
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their reliability is proven, performance can be predictable, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
