previous owner has painted the intercooler dark blue, light blue, then silver... that's 3 coats of paint... :) anyone know where I might be able to get it stripped back to bare aluminium??
called a few radiator places and they havent been able to help. some suggested sandblasting, and others suggested using a high pressure water spray... there must be a better option.
cheers,
rol
https://www.sau.com.au/forums/topic/79356-intercooler-cleaning/
i've tried using some selley's aerosol paint stripper... managed to get rid of most of the paint, but getting rid of the paint on the cooling fins are proving to be a bitch.
i've seen a number of cars around perth with blinged up gold/chrome plated front mounts. a place that does this kind of thing should be able to get rid of a bit of paint. wouldnt go as far as getting it gold plated tho. :(
nah, i'm stripping off the paint and leaving it as bare aluminium... not gona coat it with anything else. doesnt quite do it for me...
i'll keep trying with paint stripper then...
sand blasting would annihilate a cooler
paint stripper as mentioned the way to go,  ive had acid bathing reduce teh fins to "waffer thin" frailty
why you want to strip that crap off to cover it over in more crap
Go and buy yourself 4 or 8 litres of paint thinners from supershit(cheap) auto
find a tub big enough to to lay down the cooler in it and pour that nasty stuff all over it
let it soak for a couple of days and you sould be able to blow off any residue with a compressor
should be a bit cheaper than paint stripper if you buy the ultra cheap thinners
just leave the stuff in a well ventilated area as you dont want to do blowing yaself up now do you
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
