Hi guys,
As the subject says, the poor ScibyLine has been losing power lately, and it's rather annoying. Any suggestions would be most helpful.
* Car is mostly stock in terms of performance... has a cat-back Apex'i RS zorst and an Apex'i Power funnel filter, replacing a HKS super happy filter thingy.
* Changes made lately: Put new filter on and cleaned and de-meshed the AFM. Next lot was new plugs, new gearbox oil, new fuel filter (new filter was because of the power issues, thought it might have been the culprit, no such luck). ECU has been reset a couple of times, made no real changes/improvements.
* Symptoms: Idles rougher than normal, very thub-thub-thub as opposed to the usual smoothness. When accelerating from a stop, there seems to be a hole in the power, ie: the throttle at 50% gives the same acceleration as 30%, not as responsive. You have to give it a bootful to get past this hole and then the turbo will start boosting... although even when the turbo is boosting, it still doesn't have the same power as it used to. Another strange one is when coming to the lights to stop, I put it into neutral, clutch out, brakes on gently, just before it comes to a complete stop, rpm dips and the car phsycially shakes, almost like I've still got the clutch in and I'm engine-braking and letting it stall out...
NB: The clutch plate is dying, but I can usually tell when it's the cause of loss of forward motion. :P
I'm not going to put forth my ideas on what could be the problem, as I don't want to colour people's opinions and ideas... but any suggestions/tips, etc, would be excellent.
https://www.sau.com.au/forums/topic/7936-power-loss-problems-on-the-scibyline/
Sounds like something may be stopping it from breathing.. The filter is brand new and clean, so that rules out the filter being too dirty. something may be blocking the intake, perhaps, check the filter again. If it's not that, maybe it could be the fuel pump?
Hey old timer. :P nah, no FMIC yet... broke as, badly need a new clutch first... the stock one is like almost mirror finished. :P
K, ran diags before, normal tests claim "ok", but I ran the O2 sensor realtime... and it was flashing on (for "lean") every second, like: lean, rich, lean, rich, lean, rich... like it was undecided... I decided to deviate from the "Run at 2k rpm" run and revved it up through the rpms, and it was about 50/50 lean/rich... it makes me wonder if my o2 sensor is buggered, because even sitting there, I can take my foot off the noise pedal and it'll pop and fart, indicating to me that it's still running rich, as Nissan programmed it to do.
Any opinions on this?
it could have something to do with removing the screens
it changes the reading the afm gives to the ecu
so try putting the screens back and if that fixes it u will need
a mappable ecu (power fc or similar)
to remove the screens and have it run proparly
sounds like AFM but before you dump it try sparing it with carby cleaner its safe and it will get any gunk of the wire
the afm is a self cleaning unit but it still sometimes gets contaminated
removing the mesh makes no diff its there to stop lage particles entering the afm from either side
hope this helps
Originally posted by slip
mate put the mesh back on your afm, its there for a reason.  did you oil the filter?  I think the 02 sensor doing that is normal, if it was always rich or always lean you'd have a problem.  (note: i think)
Er... a bit hard to put the mesh back on, it's been literally ripped out... only the rear one though, the front one is still there...just like quite a few others have done, with no issues... *shrugs*... filter is dry type... you would think that considering the whole thing about nissan programming the skylines to be on the rich side, it would constantly state rich, or at least, for most of the time.
Probably also should mention that I demeshed the afm because I thought it may help with the problems I've been experiencing (ie, I was having the problems before I did the mesh), although it doesn't seem that way... perhaps I'll borrow a full afm from someone and see what changes it makes.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
