Armed with a datalog of an hour or so on the weekend I will go over my knock map and then up the timing as needed to aim for a knock of 10 all around the map.
Here's what a 2 minute logging run looks for like a "knock map" view for those interested. Very helpful stuff kudos to datalogit (thanks again Jono)
has anyone experimented with turning on VCT earlier or later in the rpm range? worth experimenting with or is it one of those "dont f**k with" settings?
cheers
where did you get 19deg from? you can see part of my ign map from the screen capture. ill post the entire thing tonight when i am at home. its with 0.85bar boost. full 3" exhaust. fmic. pod filter
define "load" do you mean airflow "load" if so then it runs across load point 16ish at max load as the stock afm calibartion only lets you goto load point 16ish
this is my current tune. i made some more changes tonight and have uploaded. for those who are new with datalogit be careful as the default action when datalogit is first opened and loaded (assuming plugged in OK) and if you accidently hit enter is to write the default maps over the top of your tune so be careful (what a silly design flaw).
rename the map file to .dat and open with datalogit
paulr33_193rwkw_ign_up_8_7_6_jump.txt
I'm about to go do some experimenting on my PowerFC with the help of PaulR33's map cross-referenced with mine. Since I seemed to have little trouble when testing with the +5 setting on light throttle, what I intend to do is compare the 2 maps in the N/L 1 to 10 range. Then wherever I find my timing is less than his, increase it by +5 or up to whatever he has set, whichever is less. In the areas where my timing is the same or more than his I'm leaving it that way.
Does this sound like a good idea? Anything I should be wary of that isn't already covered in the thread?
Hey Paul, you reckon you could add a quick Datalogit guide on your PowerFC manual page. If it's that easy to lose your map maybe a breif "Getting Started" with steps on how to download your current map/compare to stock map.
Just scared me with how easy it is to lose current map - I'd hate to lend to a friend and they lost their current map they spent $700 on getting tuned.
Would be great,
Penfold
Best thing to do is back up the tune manually, especially if you spent so much money/time on it. It only takes about an hour to write down all the settings from fuel and ignition maps from the hand controller. You can use a lot of shorthand in the areas where all the numbers are the same. I did that then typed it all up into a spreadsheet which was even quicker.
quick question,
if i want to speed up the spool time of my turbo, during the boost buildup load points do i advance timing to a certain point (until knocking occurs)??? Also does having it abit on the rich side at these boost buildup load points help spool or is it better be more on the lean side???
its a rb20det
cheers
george
Hey Paul, any chance of fixing up the word wrap on your FAQ? At the moment most of the text is a bit too wide to fit on my screen so I have to constantly scroll across and back again for each line while I read it.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
