For all you people out there that are wanting a Skyline (Jap car)meet-cruise here is your chance to unleash your machines.
The meet will take place on Friday the 10th of January at 9:00pm in front of the Albert park pits and we'll depart at 9:30
The meeting point is the ALBERT PARK PIT STOPS @ 9:00PM
We will be departing at 9:30pm sharp!
The cruise will head down along beach road past the elwood beach where most
likely we will stop for photos or a break etc..
Then back again along beach road heading down towards Frankston way..
We will be taking the Arthurs Seat route..
Nice Twistie Roads and scenery
Please note maps for the cruise will be handed out on the night at the
First meeting point.
https://www.sau.com.au/forums/topic/7938-10th-of-jan-meet-cruise/
  • Replies 299
I need to replace some suspension bushes on my car first, if it's finished before the 10th, I sure would like to come along since haven't been on a cruise for some time....
But please, not those bumpy rides at kangaroo ground again... I'm sure it'll only do more damages to your car's shock & suspension, not to mention loose screws on various body bits n pieces everywhere....
Since it's night time cruise, I reckon would somewhere be around the fav cruise strips, st kilda, city?
Guest NOS-GTR
fellas... u know i'm in, no worries.. yeah i think we should a pretty cruisy sort of cruise, hehe
st kilda and city sounds fine, but even as much as i would like chapel, i cant afford a canary atm.. :P
im in for wateva cruise though, bit of fun and get to meet fellow skyliners...
Originally posted by skyline33
I'm thinking albert park pits for the meet and cruise else where definetly not the city
albert park pits meeting is a good idea. Pretty central area... can head up kingsway, or south down nepean or up dandenong rd i guess.. also plenty of parking room and no hassles out that way.
yeo halfcut has been sitting at our glass factory for a month or so
better to pay someone to do it quicker than what we could do it at my house...with less headaches
never know...if this pipe on the colt gets replaced maybe i could head down for a quick meet with u guys ahaha
Originally posted by Greg
if i can con someone to sit in the passenger seat (me is on L plates) i will come along for my SAU first cruise ever :P i look forward to meeting you guys.
ahmed we could do our exchange then?
yeah sure, no problem
Originally posted by MZNISMO
how bout a nice leasurely cruise down beach road towards frankston way..
the roads arent too bad that way??
yeah that sounds good... we start off at albert park then head towards frankston.
Guest
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
